Rune Priest Jbickb Posted April 20, 2014 Share Posted April 20, 2014 Hello all, I am visiting from the space wolves forum and have decided to expand from my meager 500 Point guard allies into a full list. I was wondering if anyone thinks there would be a problem using the Militarum tempestus guys as carapace Veterans. I love the models but I was unsure if, due to the fact that they are another model in the Dex if that would be an issue. Also does anyone know how many beret headed guys with no mask come in that set? Thanks in advance Link to comment https://bolterandchainsword.com/topic/289877-carapace-vets-from-tempestus-box/ Share on other sites More sharing options...
Stercus Posted April 20, 2014 Share Posted April 20, 2014 You get five beret heads. Link to comment https://bolterandchainsword.com/topic/289877-carapace-vets-from-tempestus-box/#findComment-3658865 Share on other sites More sharing options...
hendrik Posted April 20, 2014 Share Posted April 20, 2014 currently GW doesn't sell any models, aside from colour sgt kell that are wearing carapace armour. this means that unless you want to greenstuff them, or find any of the old stormtroopers/karskin models online scions are the only available "official" carapace armour. note that the weapons used by scions are still different though than the lasguns/shotguns used by veterans! Link to comment https://bolterandchainsword.com/topic/289877-carapace-vets-from-tempestus-box/#findComment-3658883 Share on other sites More sharing options...
Nicodemus Doloroso Posted April 20, 2014 Share Posted April 20, 2014 Basically what Hendrik said. You'd have to kit bask with Cadian arms for lasguns or space marine scout arms for shotguns to get the weaponry right but otherwise you'd be good to go. As long as it's WYSIWYG you can use whatever models you want. They're humans in carapace armour do they could be officers in carapace, veterans, inquisition henchmen, or even DKoK engineers with the right weapons. Link to comment https://bolterandchainsword.com/topic/289877-carapace-vets-from-tempestus-box/#findComment-3658937 Share on other sites More sharing options...
Vash Posted April 20, 2014 Share Posted April 20, 2014 Well using them as Veterans is no problem at all. I am planing to do so my self if I include imperial guard to my Tempestus army. First of. There are a whooping 9 beret heads, not 5. And 9 of the heads with helmets. So in total you get 18 heads for 5 models... Bits anyone? The weapon, or rather the hot shot lasgun, can be converted pretty easy to a standard issue lasgun with some minor cuts. First of all you need to cut of the cables giving the lasgun the extra boost. Now the hot shot lasgun already has the lasgun magazine... so basically the cables are connected to the magazine of the lasgun. Already here we have taken away a lot of the hot shot lasgun feel. Now second part is up to your self. The standard issue lasgun has a large casing (the majority of the weapon) and a nuzzle, while the hot shot lasgun is divided into casing, barrel and nuzzle. The barrel is the suspicious part here. Now you could either cut it along the sides to make it flat (as the barrel is a thing round one), or cut it of and add another bit there and attach the nuzzle, or make the lasgun a "carbine", meaning cut of the barrel and just add the nuzzle. There are probably tons of ways of doing it. Link to comment https://bolterandchainsword.com/topic/289877-carapace-vets-from-tempestus-box/#findComment-3658973 Share on other sites More sharing options...
Rune Priest Jbickb Posted April 20, 2014 Author Share Posted April 20, 2014 Thanks for the replies guys. I have a few spare lasguns kicking around so I should be OK modding the guns or swapping them out depending on how it goes. It did look like the only carapace kit around, but I do occasionally miss things so I thought I'd check with u kindly lot to make sure that was a good plan Link to comment https://bolterandchainsword.com/topic/289877-carapace-vets-from-tempestus-box/#findComment-3659024 Share on other sites More sharing options...
Boomkapow Posted April 20, 2014 Share Posted April 20, 2014 If you are trying to save money, you can Green Stuff armor plates on the cadians. Cheap, easy, and they look pretty cool. Example: http://www.dakkadakka.com/gallery/59010-Captain%20%22Hawkeye%22%20Pierce.html As you can see this person went overboard with third party bits like Kromlech and Pig Iron. Not necessary but a cool option. Link to comment https://bolterandchainsword.com/topic/289877-carapace-vets-from-tempestus-box/#findComment-3659040 Share on other sites More sharing options...
cypherthefallenangel Posted April 20, 2014 Share Posted April 20, 2014 Edited for not refreshing my page and vash said what I was just going to say. Link to comment https://bolterandchainsword.com/topic/289877-carapace-vets-from-tempestus-box/#findComment-3659072 Share on other sites More sharing options...
march10k Posted April 20, 2014 Share Posted April 20, 2014 Muzzle. With an M. Anyway, I would let you use them as carapace vets without cutting the cables... Link to comment https://bolterandchainsword.com/topic/289877-carapace-vets-from-tempestus-box/#findComment-3659075 Share on other sites More sharing options...
Vash Posted April 21, 2014 Share Posted April 21, 2014 Muzzle. With an M. Anyway, I would let you use them as carapace vets without cutting the cables... Ha ha :D yah... Muzzle... sorry about that. Tad late when I wrote it all. Link to comment https://bolterandchainsword.com/topic/289877-carapace-vets-from-tempestus-box/#findComment-3659226 Share on other sites More sharing options...
WarriorFish Posted April 21, 2014 Share Posted April 21, 2014 I think that everything has already been covered well, I'll add that something as simple as using normal Guardsmen heads on them could go a long way to differentiate them from Scions. Link to comment https://bolterandchainsword.com/topic/289877-carapace-vets-from-tempestus-box/#findComment-3659344 Share on other sites More sharing options...
Stercus Posted April 26, 2014 Share Posted April 26, 2014 There are a whooping 9 beret heads, not 5. And 9 of the heads with helmets. So in total you get 18 heads for 5 models... Bits anyone? 9 beret heads? I must have misread the product description on GW website. Are some of those with berets and masks? Link to comment https://bolterandchainsword.com/topic/289877-carapace-vets-from-tempestus-box/#findComment-3665239 Share on other sites More sharing options...
Heru Posted April 26, 2014 Share Posted April 26, 2014 There are a whooping 9 beret heads, not 5. And 9 of the heads with helmets. So in total you get 18 heads for 5 models... Bits anyone?9 beret heads? I must have misread the product description on GW website. Are some of those with berets and masks? Only one of those nine has a mask. Though there is only seventeen heads (eight helmeted). Link to comment https://bolterandchainsword.com/topic/289877-carapace-vets-from-tempestus-box/#findComment-3665262 Share on other sites More sharing options...
Plague Angel Posted April 27, 2014 Share Posted April 27, 2014 Yeah, eight helmets, eight berets with faces, and one beret with mask. Seventeen total. Link to comment https://bolterandchainsword.com/topic/289877-carapace-vets-from-tempestus-box/#findComment-3665395 Share on other sites More sharing options...
march10k Posted April 27, 2014 Share Posted April 27, 2014 I'll bet the berets with masks will be in high demand in the bitz world Link to comment https://bolterandchainsword.com/topic/289877-carapace-vets-from-tempestus-box/#findComment-3665417 Share on other sites More sharing options...
