Saintnz Posted April 24, 2014 Share Posted April 24, 2014 Ancient Tirion Fording Captainof the Ardentguard WS BS S T W I A LD SV PTS 6 6 4 5 3 5 3 10 2+ 155 Tirion Fording may be purchased as an upgrade to a squad ofArdentguard. Unit type: Infantry (character)Wargear: Mantle of the Praetorian, Ash Bringer, Boltgun, Boltpistol,frag&krak grenades.Special rules: The faithful, The Praetorian, Divine Shield, And they shall knowno fear. Mantle of the Praetorian:As much a badge of office as it is a suit of armour. This ornate suit ofartificer armour grants Tirion a 2+ armour and 5+ invulnerable save and the feel no painspecial rule.Ash Bringer: this artefact of the great crusade belonged to one of thecustodian guards who defended the imperial palace during the Horus Heresy.Stolen by Arghast the defiler, Fording slew him at the battle of Two Suns andcleansed the weapon for its righteous use. It has the following profile: Rng: -S: +2 Ap: 3 Type: melee, soulblaze, Ash bringer, master crafted. Ash Bringer: whenever the ash bringer’ssoulblaze rule inflicts one or more unsaved wounds, roll a D6 for every unitwithin 6” of the unit that suffered the wound. On a roll of a 5+, that unit isset ablaze as for the soul blaze special rule. NOTE this soulblaze does notbenefit from the ash bringer rule. The Praetorian: Tirion Fording embodieswhat it means to be a noble warrior, upholding the virtues of the Space Marine.He is the Commander of the Ardentguard they are the Shield of the chapterstalwart in their charge. Units of Ardentguard form honour guards for thechapters command. If Tirion Fording is in your army you may take one more unitof Ardentguard than would normally be allowed. Additionally, if Tirion is incombat with a model that has the ‘independent character’ rule or ’unit type:character’, that model MUST direct its attacks against Tirion and cannot acceptnor issue challenges. When charging you must ensure the model(s) affected bythis rule end their charge in base contact with Tirion. Divine shield: A model with this rulediscards the first wound suffered in the first round of each combat they areinvolved in. Link to comment https://bolterandchainsword.com/topic/290052-ancient-tirion-fording-captain-of-the-ardentguard/ Share on other sites More sharing options...
Rapture747 Posted June 30, 2014 Share Posted June 30, 2014 He has a lot going on, which is typically not a good thing if you ever want to actually play with him (the less for your opponent to remember, the better). Good: Having him as a character rather than an IC is an interesting limitation. But without the squad's stats and rules, it makes it difficult to judge him. I think that the unique armor is a cool idea and trading a point of invulnerable save for FNP is pretty close to a wash. Bad: The point cost is a bit off. A regular Captain with artificier armor and a standard relic blade is 135 points. That is at 1 less BS and T. Toughness increases are suspect because they change the ID threshhold, which is also import when you are incorporating FNP. If we thrown in a Mark of Nurgle for 15 points and tack on the BS increase for 5 points, there is still a lot that this guy has left over. The Praetorian reads like a way to get around the limitations that a challenge sticks on combat. It will essentially allow your unit to treat opposing characters and independent characters as pinatas while their attacks bounce off the Divine shield. The Divine Shield will get you a stare from across the table when your opponent's MC hits you with a smash attack and you tell him that it doesn't count. I know that it only counts during the first round, but situationally it is very powerful. Honestly, I wouldn't be thrilled to play against him using the standard codex, but I would at least be willing to give it a shot (minus The Praetorian). Link to comment https://bolterandchainsword.com/topic/290052-ancient-tirion-fording-captain-of-the-ardentguard/#findComment-3732950 Share on other sites More sharing options...
