How to use Legion Land Speeders Squadrons?
Passeltov
They have fun rules. Who cares if it's effective?
Exactly. They are little more than glorified heavy bolters that cause extra wounds, but man they are fun!
Culverins are strength 6. Quite a bit better than HBs. Also, being able to bring them on speeders is excellent news!
I had no idea I could take graviton guns on speeders. Sounds tasty
I think a Culverin is what? 45 inch range, S6 with AP5 with Deflagrate and Heavy 4? Now that I think about it, it might just be more than the rule of cool.
The updated Landspeeder options are:
Any Landspeeder (in the Squadron) may replace it's standard armament (1 x Heavy Bolter) for one of the following:
  • Heavy Flamer
  • Multi-Melta
  • Volkite Culverin - The upgrade costs the same as the Multi-Melta upgrade.
Any Landspeeder (in the Squadron) may be upgraded with one of the following:
  • Havoc Launcher
  • Heavy Bolter
  • Plasma Cannon
  • Graviton Gun
Any Landspeeder (in the Squadron) may take:
  • Up to two Hunter-killer missiles
I'm hoping that they will indeed be tasty when combined with Multi-meltas! cool.png
Just to chime in with the idea of converting the pilots from the plastic kits here are two images of what I have done.
I cut the outer leg on each side off and trimmed the seat bit down enough so that i could glue a spare MKII or MKIII leg in place. Once you add the body and the arms, it looks OK. I didn't bother doing the inner legs as the support and console cover if from all but the most detailed of looks. This was done several years ago before they brought out new Landspeeder, and at some point I need to update the weapon options to be 30k compliant. this will involve swapping the heavy flamer for a graviton gun, because as Urza says that should be tasty.
Cheers Urza, having seen the rest of your stuff I'm certain that yours will come out looking excellent! If I was starting from scratch I might well do it your way with the melta underneath, and the gunner standing in his seat firing the graviton gun.
