Kriegsmacht Posted May 4, 2014 Share Posted May 4, 2014 Here's my first vow a priest and 3 death cult assassins. Instead of buying the metal models I instead took 3 Wytches I already made and modified them to have 2 swords(ish) and greenstuffed the pads and hoods. These miniatures are taller than the Sisters so for fluff reasons I'm just gonna say that the Priest has a thing for strong Amazonian type of female assassins. So to bring my Nerdism to front the priest is named Caesar and the assassins are Xena, Gabrielle, and Callisto. :D Link to comment https://bolterandchainsword.com/topic/290591-kael24s-etl-iii-vow/ Share on other sites More sharing options...
Captain Semper Posted May 4, 2014 Share Posted May 4, 2014 Good luck Kael, they look very promising there! :tU: Link to comment https://bolterandchainsword.com/topic/290591-kael24s-etl-iii-vow/#findComment-3674404 Share on other sites More sharing options...
Naminé Posted May 4, 2014 Share Posted May 4, 2014 I like the names, but they just took xena off netflix :( Looking forward to seeing them painted! Link to comment https://bolterandchainsword.com/topic/290591-kael24s-etl-iii-vow/#findComment-3674467 Share on other sites More sharing options...
Kriegsmacht Posted May 5, 2014 Author Share Posted May 5, 2014 Well here's my first DCA wanted to show it off a bit. I've only done block painting gonna do a few touch ups and then dip her. ONce I dip all fours minis I'll start basing and try to do some highlighting. Enjoy Link to comment https://bolterandchainsword.com/topic/290591-kael24s-etl-iii-vow/#findComment-3676008 Share on other sites More sharing options...
WarriorFish Posted May 7, 2014 Share Posted May 7, 2014 You'll be done in no time like this, good work Kael. What are you going to be dipping them in? Link to comment https://bolterandchainsword.com/topic/290591-kael24s-etl-iii-vow/#findComment-3678175 Share on other sites More sharing options...
Kriegsmacht Posted May 9, 2014 Author Share Posted May 9, 2014 @namine That sucks about Netflix. I have all 6 seasons on dvd...come to think of it I haven't watched any episodes in a while. Fun show to watch while I'm painting. @Warriorfish Already have paint on all four miniatures. The priest is fun to paint. I bought 2 packs of 5 Cultists a while ago and they had the same minis in them so needed to find some way to use them. As far as dip goes I have Strong and Dark Army Painter Quickshades. I tried out strong on some other miniatures and it turned out alright just have to watch out for pooling in some areas. For these minis I'm not quite sure wich one to use. I'm gonna test out the dark quickhade this week-end on another mini and see how that looks. Link to comment https://bolterandchainsword.com/topic/290591-kael24s-etl-iii-vow/#findComment-3680941 Share on other sites More sharing options...
WarriorFish Posted May 9, 2014 Share Posted May 9, 2014 I have no experience of using dips so I'm interested to see how it turns out. I imagine it's like dunking your models in a vat of Agrax Earthshade - the wash for all occasions :P Link to comment https://bolterandchainsword.com/topic/290591-kael24s-etl-iii-vow/#findComment-3680967 Share on other sites More sharing options...
Kriegsmacht Posted May 9, 2014 Author Share Posted May 9, 2014 Yeah basically you dip the mini in the can. Shake the excess off onto paper or plastic and then some fine tuning. Hopefully i'll make good progress this week-end. Link to comment https://bolterandchainsword.com/topic/290591-kael24s-etl-iii-vow/#findComment-3681925 Share on other sites More sharing options...
Kriegsmacht Posted May 17, 2014 Author Share Posted May 17, 2014 WEll I finished my first vow. Priest and DCAs are done. Yayyyy Here they are. Basing and the blood is new for me. Glued sand to the base and then mixed Forgeworld Fresh Mud and Matte Varnish together and applied onto the sand. Applied Tamiya clear red on the blades. After spraying matte varnish on the model I went back and brushed gloss varnish on the clear red and the mud. After looking the models I thought things over for the next vows I'll work on. I'll probably switch to Dark Tone Quickshade when I start the SoB Troops. Strong is fine and will probably work well with the skin and clothes of the Sisters Repentia but I feel Dark Tone will make the shading on the armor stand out better. I also have to be more patient when brushing on the Fresh mud. Some of it went on the edge of the base and made it difficult when I put graveyard earth on the dark mud would show through. Over-all I'm happy with these minis and can't wait to start my next vow. Link to comment https://bolterandchainsword.com/topic/290591-kael24s-etl-iii-vow/#findComment-3691445 Share on other sites More sharing options...
WarriorFish Posted May 17, 2014 Share Posted May 17, 2014 Well done Kael! :D I'm afraid I have no idea what you're talking about with the tones and quickshades though :P Link to comment https://bolterandchainsword.com/topic/290591-kael24s-etl-iii-vow/#findComment-3691472 Share on other sites More sharing options...
Kriegsmacht Posted May 17, 2014 Author Share Posted May 17, 2014 This is the can of Strong Quickshade I used. From what I read it's the equivalent of Devlan Mud. Also have dark tone which is the equivalent of Nuln Oil(again from what I read). Not only can it be brushed onto the mini you can dip the whole mini in and then shake the excess off which is what I did. Not only does it create shading but it's also a gloss varnish which is easily remedied with matte varnish spray. Not sure if that helps explain any better(I have a hard time explaining things out) but hope it helps a little. Oh also there's a hint of my next vow in the pic. :) Link to comment https://bolterandchainsword.com/topic/290591-kael24s-etl-iii-vow/#findComment-3691484 Share on other sites More sharing options...
David Ravel Posted May 17, 2014 Share Posted May 17, 2014 I really liked the Quickshade when I did my 50+ cultist and my 40+ infantry guardsmen. Yet for individual model, I much prefer Nuln Oil for more ''accurate'' shading. You can also put your model on top of a drill, dip it, and then use the drill to twist and shed the excess of Quickshade. Quickshade has a really cool shading, I like it. Link to comment https://bolterandchainsword.com/topic/290591-kael24s-etl-iii-vow/#findComment-3691504 Share on other sites More sharing options...
