Ldorte's ETL III
Good work, it looks very weathered! I think it could benefit from some block colours added, even if it's only simple things like painting the heavy bolter case black for example.
You know what to do next, my Baneblade feels so lonely...
So sad, so very sad. If only there was a friend who truly understood what it is to be a super heavy...
I like the rust effect it looks great. Did you use Typhus corrosion with Ryza rust or did you use a different technique?
By the way that is a nice collection of tanks. Can't wait to see the Baneblade painted.
Thanks, I don't just use gw paints as it does limit your colour choices somewhat and I find mixing to be a pain on larger models tongue.png
On the russ I used:
GW: Chaos Black, Fortress Grey, Shadow Grey and a little bit of Boltgun Metal (although I think I covered most of that up lol)
Vallejo: Flat Brown, Copper, Brown Violet
Humbrol: Sea Grey, Rust Wash
The rust was basically rust wash with a bit of brown violet over the top in places and then the odd bit of flat brown
No progress today I'm afraid, once I've had some sleep though I've got a 7-9 hour monster painting session planned, vow 3 may even be started tonight :D
As I thought the ETL ended in june (not sure why) I've been a bit on the small size with my vows so far, so the next one should be a bit more hefty :)
Right the 3rd vow is here and we are continuing with the tank theme with 3 more leman russ tanks :)
http://i.imgur.com/kURxk3I.jpg?1
Have made some progress already due to the blazing sun outside drying the spraypaint in an impressive 5 minutes!
http://i.imgur.com/PLDlbSy.jpg?1
Hah I'll slow down quite dramatically once I get to the infantry vow!
Unfortunately I ran out of sea grey spray 2/3 of the way through the 3rd tank (probs not visible in the pic), shockingly my copper is getting quite low aswell so I wont be finishing this vow till thursday/friday sad.png
Want to get started on the infantry asap as I have somewhere within the region of 150 ready to be started if you include the hq and elite units, I have a feeling vow 4 is gonna take a while (oh and a hellhound and sentinel)
