lhg033 Posted May 13, 2014 Share Posted May 13, 2014 hi all, before I pry apart some of my old, unpainted terminators for parts - how interchangeable are the Deathwing knights/terminator torsos with the standard TDA kits? i'm hoping that one command box should be able to make some knights then I can mix and match the remaining bits to add some character to some of the more standard looking terminators I have. Thanks, lhg033 Link to comment https://bolterandchainsword.com/topic/291024-mixing-kits/ Share on other sites More sharing options...
Hemal Posted May 13, 2014 Share Posted May 13, 2014 Not tried yet but I had teh same idea myself.. Link to comment https://bolterandchainsword.com/topic/291024-mixing-kits/#findComment-3685650 Share on other sites More sharing options...
deathspectersgt7 Posted May 13, 2014 Share Posted May 13, 2014 I have used some helmets and arms but no torsos. Link to comment https://bolterandchainsword.com/topic/291024-mixing-kits/#findComment-3685690 Share on other sites More sharing options...
battle captain corpus Posted May 13, 2014 Share Posted May 13, 2014 If memory serves me correctly they are more or less fine for swapping over between. The one thing to bear in mind though is that the robed torsos require normally the legs to be in a certain position otherwise it can look weird. BCC :) Link to comment https://bolterandchainsword.com/topic/291024-mixing-kits/#findComment-3685697 Share on other sites More sharing options...
lhg033 Posted May 13, 2014 Author Share Posted May 13, 2014 many thanks. I figured the robed torsos may be a bit like that. back in the day I desecrated any PA tabards (champion/black Templars etc) I could get a hold of to make DW which looked okish then - I don't think they will measure up with the current range very well though even if the poses are a bit static. I reckon from two Deathwing boxes I can make 5-6 stock Deathwing Knights then trick out 2-3 regular termie squads of 5 though I'll have a couple of plain shoulder pads among these or see if I have any spares from the veterans upgrade sprue/forgeworld pads the other thing I am going to do is put the rw grenade launcher front on a standard bike along with some of the other RW bits to make 4 bikes from the black knights kit- I don't predict major issues with this Link to comment https://bolterandchainsword.com/topic/291024-mixing-kits/#findComment-3685790 Share on other sites More sharing options...
Vijok Posted May 13, 2014 Share Posted May 13, 2014 I have 50+ termies and I can say: yes, You can (with a little bit of knife work) mix every kit. I've used parts from: Deathwing Command, standard termies, DV and AoBR. As noted above, the only problem is with robed torsos, 4 out of 5 can be mixed with normal legs. Link to comment https://bolterandchainsword.com/topic/291024-mixing-kits/#findComment-3686021 Share on other sites More sharing options...
