David Ravel Posted May 14, 2014 Share Posted May 14, 2014 Greetings, I decided on what colours to use for my Battle Sisters, but I'm not quite sure with the tanks. I will pass on the fluff for now, but my scheme is taken from the Argent Shroud (as is my minor Order), but with blue added. http://vorace-art.com/wp-content/uploads/2013/04/Victoire_HR.jpg (from Nicolas Francoeur, see here : http://vorace-art.com/) This is the concept art I used to think about my colours. Blue/White cloth with silver armour and golden lys/details. But for the tank, I'm not sure. Should I go full silver with blue ? With white ? Full white with blue ? Full blue with white ? Any thoughts, ideas, opinions ? Someone have painted them with those colours that can give me tips or if those colours works bad on tanks ? Thank you. Link to comment https://bolterandchainsword.com/topic/291050-painting-question-to-white-or-not-to-white/ Share on other sites More sharing options...
McFisty Posted May 14, 2014 Share Posted May 14, 2014 I think any combination of those colors would look fantastic. One trick I have used is to print out a black and white copy from a webpage of the model I am considering. Then, draw on it with ink pens or colored pencils to help me see and conceptualize the possibilities. I hope that helps. Link to comment https://bolterandchainsword.com/topic/291050-painting-question-to-white-or-not-to-white/#findComment-3686619 Share on other sites More sharing options...
WarriorFish Posted May 14, 2014 Share Posted May 14, 2014 I think you need to keep the colours matched across infantry and vehicles. The primary colour on your troops will need to be the same on the tanks, otherwise the difference between them may be too much and they'll look like different armies on the table. Silver is a good colour and will go very well with blue and white but I think it looks better the less you use - large blocks of it don't look great. Fortunately Rhino chassis have plenty of bits for you to break it up on easily and of course you can add as many SoB iconography as you like so I reckon it'll look nice on Sisters :) With vehicles the larger flat surfaces require special attention but nothing major. Work up thinner coats with smooth brush strokes in a single direction and they'll be done nicely in no time. If you're handy with an airbrush then even better! Link to comment https://bolterandchainsword.com/topic/291050-painting-question-to-white-or-not-to-white/#findComment-3686753 Share on other sites More sharing options...
David Ravel Posted May 14, 2014 Author Share Posted May 14, 2014 @McFisty : I will try that, it's a good idea, especially with tanks. @WarriorFish : Good thinking, I will try to figure out the best part of the colour of my models (probably blue), and think accordingly. I will keep silver for extra-armour etc. like it is for my sisters. Thanks. Link to comment https://bolterandchainsword.com/topic/291050-painting-question-to-white-or-not-to-white/#findComment-3687182 Share on other sites More sharing options...
Knight of the Raven Posted May 14, 2014 Share Posted May 14, 2014 You can look at pre heresy World Eaters rhinos if you're curious about full white with blue. Mars pattern Deimos pattern Link to comment https://bolterandchainsword.com/topic/291050-painting-question-to-white-or-not-to-white/#findComment-3687648 Share on other sites More sharing options...
David Ravel Posted May 14, 2014 Author Share Posted May 14, 2014 Yes they look great. I could go with that. I can adapt it easily for Immolator/Exorcist. Thanks everyone ! Link to comment https://bolterandchainsword.com/topic/291050-painting-question-to-white-or-not-to-white/#findComment-3687747 Share on other sites More sharing options...
WarriorFish Posted May 14, 2014 Share Posted May 14, 2014 As long as it's not too similar... :P Link to comment https://bolterandchainsword.com/topic/291050-painting-question-to-white-or-not-to-white/#findComment-3687810 Share on other sites More sharing options...
march10k Posted May 14, 2014 Share Posted May 14, 2014 My Order of the Mourning Rose [OMR] uses blue and white, I think they go well together! Link to comment https://bolterandchainsword.com/topic/291050-painting-question-to-white-or-not-to-white/#findComment-3687903 Share on other sites More sharing options...
David Ravel Posted May 15, 2014 Author Share Posted May 15, 2014 @march10k : Could you be so kind as to post a picture of your tanks to give me an idea ? Link to comment https://bolterandchainsword.com/topic/291050-painting-question-to-white-or-not-to-white/#findComment-3687969 Share on other sites More sharing options...
Dread Posted May 15, 2014 Share Posted May 15, 2014 I don't know if this will help but when I did my Deathwing, I started with a black primer, then dry brushed a dark grey to a lighter grey and still lighter then to white. I really like the white I achieved from this and use a like method on my GK. but just to grey and I use a pearl in the mix for them. Can't wait to see yours I bet they will be great. If you want, check out in my album to see my DW land raiders. Link to comment https://bolterandchainsword.com/topic/291050-painting-question-to-white-or-not-to-white/#findComment-3688182 Share on other sites More sharing options...
David Ravel Posted May 15, 2014 Author Share Posted May 15, 2014 Thanks Dread ! I like that feel very much. Very battleworn, which is something I prefer on my tanks. I will definitivly use that to paint mine, and add some blue. Link to comment https://bolterandchainsword.com/topic/291050-painting-question-to-white-or-not-to-white/#findComment-3688633 Share on other sites More sharing options...
Duke Danse Macabre Posted May 15, 2014 Share Posted May 15, 2014 It will look good if its broken up right but the main reason people don't waiting white is its a massive pain to get right. Do one sister first, work in dividing colours at the joints like Ulthuan Grey and see how it turns out, personally I decided to stick with the traditional colours and add a second force of white for a small detachment option if ever I need to field more than 2000 points. Link to comment https://bolterandchainsword.com/topic/291050-painting-question-to-white-or-not-to-white/#findComment-3688651 Share on other sites More sharing options...
David Ravel Posted May 15, 2014 Author Share Posted May 15, 2014 Yeah maybe it will be difficult. I haven't painted much white and I know its difficult. That's why my sisters primary color are gonna be blue and silver. For the tanks, I like them battleworn, so if I can achieve a good ''white but battered'' effect on the tank, I'm gonna be happy ! Link to comment https://bolterandchainsword.com/topic/291050-painting-question-to-white-or-not-to-white/#findComment-3688780 Share on other sites More sharing options...
march10k Posted May 16, 2014 Share Posted May 16, 2014 @march10k : Could you be so kind as to post a picture of your tanks to give me an idea ? Link to comment https://bolterandchainsword.com/topic/291050-painting-question-to-white-or-not-to-white/#findComment-3690174 Share on other sites More sharing options...
David Ravel Posted May 17, 2014 Author Share Posted May 17, 2014 Very good indeed. Now I'm hesitating between white on blue and blue on white, lol. Link to comment https://bolterandchainsword.com/topic/291050-painting-question-to-white-or-not-to-white/#findComment-3690733 Share on other sites More sharing options...
march10k Posted May 17, 2014 Share Posted May 17, 2014 Blue is easier to paint, lol...but those smokestacks are a royal pain! Link to comment https://bolterandchainsword.com/topic/291050-painting-question-to-white-or-not-to-white/#findComment-3690745 Share on other sites More sharing options...
David Ravel Posted May 17, 2014 Author Share Posted May 17, 2014 @march10k : What blue did you use for this btw ? For those of you who uses the red-gold-black of the ''classical'' Sisters. What red do you use ? Thanks. Link to comment https://bolterandchainsword.com/topic/291050-painting-question-to-white-or-not-to-white/#findComment-3691505 Share on other sites More sharing options...
Kriegsmacht Posted May 17, 2014 Share Posted May 17, 2014 I'm planning on painting my sisters armor with Mephiston Red. I used it for my priest and DCAs in my first vow and I like it. Link to comment https://bolterandchainsword.com/topic/291050-painting-question-to-white-or-not-to-white/#findComment-3691528 Share on other sites More sharing options...
march10k Posted May 18, 2014 Share Posted May 18, 2014 @march10k : What blue did you use for this btw ? For those of you who uses the red-gold-black of the ''classical'' Sisters. What red do you use ? Thanks. Kantor blue Link to comment https://bolterandchainsword.com/topic/291050-painting-question-to-white-or-not-to-white/#findComment-3691878 Share on other sites More sharing options...
Knight of the Raven Posted May 19, 2014 Share Posted May 19, 2014 For those of you who uses the red-gold-black of the ''classical'' Sisters. What red do you use ? I used the old Red Gore, though I did paint one exorcist with Scab Red by accident one day. No idea what these are now, but the closest Army Painter matches are Dragon Red and Chaotic Red, which I now use. Link to comment https://bolterandchainsword.com/topic/291050-painting-question-to-white-or-not-to-white/#findComment-3693204 Share on other sites More sharing options...
