Is it possible to magnetise the Baneblade kit in order to field any of the variants as you see fit?
Its totally possible and its not that hard. It will take you longer to build and painting can be a little tricky if you try to get all your lines to look seamless between the different configurations. The end result is awesome though. Check out my hexblade. The older stormsword kit could build 6 variants. http://www.bolterandchainsword.topic/281027-ctfas-renegade-artillery-regiment/?p=3586516
It is, I'm planning on doing it with mine when I get round to it (unfortunately likely not in time for the ETL). We've a couple of topics that you'll want to read:
cypher's working link
Argun's, our resident artilleryman
What we're lacking is a step by step guide. Given the amount of work required to build and magnetise a super heavy like this it's probably a lot to ask for a guide too, but it'd be appreciated if you could! I plan on creating a guide when I do it, but I struggle to find enough free time these days so it will be a long time coming :(
