Making a power Whip
Well, the easiest way I can think of is to use one of the Dark Angel Ravenwing power sword arms (they have an angled-hand hold rather than the straight-hand hold most other models have) and cut off the sword above the top of the hand.  Get some thin wire, bend it to whatever shape pleases you, and drill it into the top of the hand.  Then use green stuff to cover the wire, tapering from thick at the base to just barely covering the wire at the end.  Maybe put another thin wire bit at the base of the whip coil to signify the "power" aspect, or just paint it electrified.
Astral claws techmarine dude on FW site has two if you could find a use for the conversion beamer on him
Was just about to recommend this actually; in a pinch you could duplicate the look with a thin wire that has been bent with some strategically placed and glued beads down the length of the whip.
Thanks for the advice brothers. got some wire in the shed so ill dig that out and get  to work with the basic build then try and get some green stuck work done. That techmarine whip is very tempting but im working on some tentacles for a warpsmith that look exactly like them so ill pass on them for now.
