Death Korps of Krieg Costume
Hi all! Not sure if this is okay to post or not but Ive worked very hard and very long on this and thought it would be nice to share with all of you here biggrin.png tumblr_n5mw67Y0Dj1re0l1qo1_500.jpgtumblr_n5mw67Y0Dj1re0l1qo2_500.jpghttp://i.imgur.com/jkKaIqh.jpg?1http://i.imgur.com/lH56zWK.jpg?1http://i.imgur.com/om3eXFo.jpg?1http://i.imgur.com/1SKZxCS.jpghttp://i.imgur.com/Z9GETaa.jpgt
https://bolterandchainsword.com/topic/291129-death-korps-of-krieg-costume/
overall it looks  very good!
have you considered looking for a new gasmask without the filter unit in front? althernatively you could cut it off and cover the gasmasks front in synthetic leather yourself, covering up the hole left behind.
The same goes for the helmet, have you considered hammering the sides a bit (i'm assuming it's a steel one) so they are turned more to the fase instead of flaring outwards that much. you can also add the typical brim running across the top that the DKOK models feature. cover it up with some epoxy/whatever and give it all a grind to smoothen it again, than repaint again.maybe even add a 3D aquila instead of a painted on one?
another good idea is to elongate the barrel of your lasgun and adding the typical lasgun nozzle.
last but not least you could add the armoured plating to the gloves and do with some more(starting lower) leg bindings.
aside from the above i don't think i can give anymore constructive tips. you've already gone a long way. keep on marching trooper!
