Gale Force 9 Basing Sand
Uprising is the pet store stuff really any good? I've heard it is but never tried it myself, always just stuck to GW sand etc.
Theres quite a bit of difference between varies suppliers sands too...genuinely though the only basing material I really loved was the old GW "mixed sand" which had various textures which was great!
BCC
Sharp sand is the stuff use in the building trade. It's got a mix of grain sizes in it. Probably cost the same for a sack of it as GWS sells a small pot for!
Same with spray paints and tools and gs. All can be found much cheaper and better quality without much hassle. You just need to let go of GWS's tight hold of you. :)
BCC
Yes, I use it for every mini I base, basically the same thing imo. Here are some WIP shots
http://i63.photobucket.com/albums/h142/Uprising014/World%20Eaters%20ETL%203/DSCN0251_zps3ef05cf8.jpghttp://i63.photobucket.com/albums/h142/Uprising014/World%20Eaters%20ETL%203/DSCN0253_zps09ce9320.jpg
I thought I might throw this out there. Here are a few common (and cheap!) basing options many people use.
Full size pic here.
The top two are plain old Kitty Litter. The grains are large and make good rubble pieces. You can crush it easy enough to make it finer and give it a more varied shape and size of grains. For this I put some on the work table and crushed it with a hammer. PRESS with the hammer head; DO NOT WHACK IT! :lol: you just want to slowly grind it up. A mortar and pestle would be best but I'm not putting cat litter in my good kitchen tools.
The next two are found at most craft stores. Ballast is used by train modelers and can be found near the modeling section. The fine sand is from the kids craft section and comes in different colors. For both of thesea pint sized container will cost less than a GW brush and will quite litterally be a life time supply of miniature basing sand.
And finally, premium desert dust. Seriously, I live in a desert and swept this up from my patio this morning. It is very fine and not great for giving a texture but included for the low end of the coarse to fine scale I seemed to have gone with.
I picked up a quad pack of various sizes from Galeforce, here's a visual.
I also bought those almost 5 years ago, still got plenty around, even after basing all my old Marines Malevolent and Astral Claws. They were worth the cost.
Did you glue the model down first then base or base then glue?
I used to use sand from a park sand pit which I mixed some old flock into. Think the total cost was about 99p.
My current bases use a mix of milliput to build it up a bit. I press stones onto the surface to give it texture. Add some tiny bits of smashed slate (found from near a garden which had slate and crushed with a hammer). Then Vallejo Grey Pumice paste to cover.
I'll be doing some wooded/dirt bases soon which will use milliput for shape and actual dirt for the texture.
Trying to keep cost as low as possible these days.
