what is a Kharybdis drop pod?
Tiger9gamer
It's a mess.  It's an assault vehicle that has a special weapon that prevents you from disembarking, plus you can't assault when you arive from reserves.  As far as I can tell, you either use it as a very expensive drop-pod for 20 dudes (or one dread), who then have to hang out and get shot for a turn, at which point you then have the thing scoot around the board heat blasting and/or pinning things, or you use it as a storm raven, fly on, then hover and assault, except without the heavy firepower of the raven.
The storm launchers might not be bad, S6 and pinning, but you're looking at Land Raider points for AV12 and not a lot of damage potential.
Long story short, you're paying a lot of points for an assault vehicle that isn't easy to actually assault out of.
I'm more seeing this as a means to get certain units on the board or in good position. since it could hold 20 people, i thought about using it to deliver 9 Terminators with varios combi-weapons along with an apothecary and preator to get a very very hard to remove squad that can take units down. It's cheaper than a spartan for what it can do. OR, use it to establish a beachhead with a 20 man tactical squad  in an area that you can't really get to normally. I see it as an Apoc Vehicle mostly, and would probably use it as such
I just used it to drop 9 Termis with Combi Plasma and a Lord in the back with a Black Mace. The former shoots everything first turn, the latter assaults the next turn. And while that draws attention, the pod can still fire 10 Str 6 shots the next turn. So not completely useless.
Edit - Course that was 40K, but hey similar for 30K
  • 3 weeks later...
I see this as it pods in, the guys stay in there, it hovers about to where you need it then assault out of it!
Am I reading these rules incorrectly? I don't think you have to disembark the turn you arrive, or what's the point in it being an assault vehicle?
With the ability to drop 20 potentially game changing guys in on t1, able to assault t2, drop a load of fire off with it as well.
Add this to the hidden blade emperors children row, and that's a precision strike force potentially devastating people on t2/3!
