Psykers and BoP
Doesn't this now mean that if you have a unit of them (but now, why would you ever take more than one per squad...) when they Peril, only one dies?
Yes, that's what it says in the BoP section of the special rules.  Randomly allocate the Perils of the Warp attack to a single model within the unit.
Yes, but as far as I can tell, that unit would only get one power roll, so as stated above, you'd never take more than 1 per squad
What, I don't understand this?  A Strike Squad, for example, can roll as many dice as you feel like letting them roll from whatever is available in your Warp Charge Pool to attempt to cast Hammerhand, for example.  They could easily Perils if you attempt with several dice (although the chance is still reasonably low).
V
Unit of 11 Warriors, 1 Psyker.
Psyker perils and a Warrior Accolyte dies?
Oh rules.  I Guess GW didn't realise that a mini with BoP could belong to a unit of non Psykers...
I SUMMON THE WARP!!!
OH NOES, I CAN'T CONTROL IT!!!
*Billy the Guardsman gets sucked into the warp*
HA HA!
Edit: Nope, it's all good.
The BoP rules stats that Perils are randomly allocated to any member of the unit with the BoP *rule*.  Even though a mixed unit is treated a a Psyker unit, the Warrior Accolytes don't have the BoP rule, so can't take a Perils.
Heh.  GW got it right for once. ;)
/salute
