Grey Knight Force to sort out a Deamonic incursion.
SCOTT_FRANCIS
Well met Brothers of the Secret Chapter 666.
(Whispers..."Is that okay, or will I get mind wiped for that")
I come seeking advice. I intend to add a small hard hitting force of Grey Knights as Allies in any Deamonic battles I fight.
I have ordered the Codex, but am away from home right now (forces stuff) so was wondering what to use.
I was thinking...
Librarian, Terminators (not sure which ones, you have so many to choose from) and a Nemesis Dread Knight.
Libby to help counter the Psychic stuff ( I'm a Templar, forgive me ), Termies to get into combat with the little ones and the Dready to fight any big ones that turn up.
As to weapons or which Termies?
I open the floor to the experts, The glorious Grey Knights. Any tips or advice would be gratefully appreciated.
How many points do you plan to spend on this Strike Force? 500? 1000?
Do you plan to assault the daemonic forces or shoot them to bits?
How do you handle a large Bloodthirster?
An example could be:
Ordo Malleus Inquisitor
Empyrean Brain Mines
3x Servo Skulls
Psyker
Terminator Armour
Grey Knight Terminator Squad
7x Terminators
2x Nemesis Force Daemonhammer,
5x Nemesis Force Halberd
Thats 8 deepstriking models with TDA - 5 halbards as most daemons dont have 2+ armour. The hammers are there to make sure you kill whatever you assault.
The skulls make sure you can make a reliable deepstrike.
Aaaanddd its only 394 points :)
Thankyou for your input Brothers. To answer your questions...
1) I was looking at around 450 - 550 points.
2) I was hoping for a little of both, Deep Strike in, shoot them a bit, then charge in to glorious close combat the turn after.
3) Is not the Dread Knight for bigger Deamons?
I have never thought of GK as an army, so have no idea. Sorry.
Re think following the post from Brother Berle.
Ordo Malleus Inquisitor, TDA, etc
GK Terminator Squad.
8 Terminators
1 or 2 Psi Cannons
2 or 3 Nemesis Force Deamon Hammers
The remainder Nemesis Force Halberds
After doing some (much needed) research, I believe I have my GK Strike Force.
   Servo Skulls
   Psyker
   Terminator Armour
   Psycannon
   10 x Terminators
   2 x Nemesis Force Daemon Hammer and Storm Bolter
   8 x Nemesis Force Halberd and Storm Bolter
   2 x Nemesis Force Halberd and Psyannon
As I have not yet received my C:GK, it is in the post, I am guessing about 600 points.
   Servo Skulls
   Psyker
   Terminator Armour
   Psycannon
   10 x Terminators
Not a bad guess. If you exchange the Psycannons for Psilencers on the terminators then you would have made your budget. I would also recommend them if you know your going against daemons (and even if you're not).
Hi Scott! I suspect a lot of people will be in the same boat as you, trying to work some GK into their normal force simply to counteract the craziness that is soon to be demons. I assume for your small list there that you meant 6 GKT with halberds (right now there's 8 and the squad adds up to 12 msn-wink.gif ). Assuming those numbers, that squad runs 470 points WITH psybolt ammo. The total, including the HQ (with 3 skulls), is 589, which is a pretty modest detachment but gives you good anti demon power. I know a lot of people are talking about how good Purifiers now are, so you may also want to look into them as a possible alternative biggrin.png . With Purifiers, you could get more warp charges on the table, which of course is useful for shutting down demons. Just an idea! So early in the edition no one knows what the cream of the crop is just yet.
Purifiers are still PML1 so they're just as good as terminators at producing warp charges. Taking purifiers without Crowe means you're running an unbound list, unless you also include those terminators. Why not go for broke and just get a full GK army tongue.png
Ah I see yes. Taking cheaper PAGK means you can take more. Purifiers are undoubtedly the best unit we have and can score too. Terminators are good if they're assaulting a unit on an objective.
Inquisitor, TDA, Psycannon, PML1, (110)
5x Strike Squad, 1x Psycannon, 4x Halberd. (130)
10x Purifiers, 4x Psycannon, 4x Halberd, 2x Hammer, Psybolt Ammo. (218)
Total: 558
You wont be disappointed with that list.
I agree. I think the beauty of GK right now is the options we are provided. Psykers are coming into their own here in 7th (more so even than 6th) and obviously GK excel there. I think a lot of people agree that Purifiers are the best right now (and like I said it seems a little early to declare that). That said, strikes are still great, as are terminators and if you wanna run a terminator with land raider list, now's the time (especially since, if I'm not mistaken, Land Raiders get sanctuary now biggrin.png ).
And then throw half of it away. The FAQ made some drastic changes.
I must have missed something... What happened to Land Raiders? The main things I saw was they gained Sanctuary, which seemed like a nice buff.
They still do, top of page two on the right column.
Oh, your units all seem to come from two or three boxes, thats great for conversion fans, lots of extra weapons and stuff. Heck throw in some standard marine bits and you could almost build two different squads from each box!
Other than the bodies. Cuz they are special, all those Hoods.
600 Points;
OM Inquisitor, TDA & NDH, Psycannon x7
Total: 560 Points.
No Psychics, but 21 Wounds and 7 Psycannons.  Pew Pew.
Backed up by S6 Thunderhammers.
Edit: Points per Wound, an OM Inquisitor with a Psycannon is more efficient than a Paladin.
A Paladin rocks in at 27.5 points per wound, while the Inquisitor (with a Psycannon no less) is 26.66~
I am torn, Brothers.
The Grey Knight models look amazing and with the extras you get in the PA kit, very easily spread around normal marine kits to quickly add up to a useful force.
Although that tiny little voice in my head will nag at me for ever if I do that, So I will probably end up using magnets and be able to use one squad for most things.
I am torn between Deepstriking a Terminator Force or Drop Podding/LRR a bigger PA force.
I am only taking 1 x HQ and either 1 or 2 troops.
I like the idea of a big 10 man Strike Squad, Halberd/SB x 6, PsiCannon x 2, Hammer/SB x 2, Psibolt Ammo, in a FW LRR with an OM Inq with Hammer/SB, Psyker.
But I love the idea of Deep Striking Terminators. 2 x Hammer/SB, 6 x Halberds/SB, 1 x Sword/PsiCannon and an TDA OM Inq with Pysker Halberd/SB.
Don't tell the Templars but, I may just build a 2000 point GK army!
If you are considering a force of PA Marines instead of Terminators, then i wouldnt go with a Strike Squad for assaults. They are just regular marines at that point (with force weapons)
You could do Purifiers but they require some kind of transport - That will most likely be a landraider since you want them to assault.
Suddenly this becomes a very expensive force. A land raider alone is 250p and then add another 100 for the Inquisitor and then at least 130 for Purifiers (5xHalbard)
Thats 480p at least.
A force of:
Inquisitor
TDA, Hammer, Pysker
10 Purifiers
3 hammers, 7 halbards
Land raider redeemer
psyflame ammo
Total: 665 points (give the land raider searchlight so you end up with 666 points :D)
I think you could be a more dangerous force for less points with terminators and deepstriking.
A force of:
Inquisitor
TDA, Hammer, Pysker
10 Purifiers
psyflame ammo
Total: 665 points (give the land raider searchlight so you end up with 666 points biggrin.png)
Ha ha ha, that is a target, what ever force I end up with, it must add up to 666 points. msn-wink.gif
It has to be a legal, Battle Forged I believe is the new term, I want my Black Templar LRC to be scoring. So HQ and 1 x Troops minimum.
I love the idea of the GK teleporting into the middle of the enemy, spraying SB and PsiCannon fire every where then charging the nearest Deamon/witch. But if I do that, they will most likely end up getting charged, not an issue with 6 Halberds and a couple of Hammers.
I need hands on my new C:GK to make a good decision, I have also found (during research) that a lot of GK players feel the same way about your current Codex as Templars do about being rolled into the C:SM. It's censored.gif . So I got an old edition to get proper Fluff.
