Top Raven Assault Units
Gaz1858
Thanks guys. This was my initial thought:
2 psykers on divination
Priest
7 crusaders
Reroll 3++ with prescience and hopefully sanctuary for 2++. Bearing in mind the GM with loadout above will be joining.
Anyone used the priest? Is his LD to low to be good?
Alternately, you could get a squad of 8 Purgators with 4 Incinerators and 4 Halberds for 180 points, giving you less of a CC only unit, but combined with the GM you would have 5 x S6 AP4 templates coming out of the Stormraven for some amazing firepower before you actually charge in, followed by several S6 (from Hammerhand) AP3 I6 attacks on the charge... Should be able to take pretty much anything except Terminators or MCs.
If you're gonna bother with Knights, take Purifiers instead. They don't cost much more and are much more effective in melee. Also, their psycannons aren't insanely overpriced, if you don't want to take incinerators.
