Soft primer
I have always had a problem with primer going on soft, if that makes sense. Wether it's from a can, brushed on, or airbrushed, I can always scrape it off easily. I don't think that's normal. I've tried various methods, like using multiple thin coats and whatnot but it just never seems to change. I often don't bother priming at all anymore. Has anyone struggled with this and found a solution?
https://bolterandchainsword.com/topic/291793-soft-primer/
Also where are you priming them comes to mind?
Priming in high or low temperature environment can dramatically change the sprays properties. Here in the UK we have a quite moderate temp scale compared to other areas of the world, so I spray in the garage or out back in the garden.
Leaving your spray cans in the area you are going to spray in, so they come to roughly the same temp is also handy. Spray cans after prolonged use will get cold also, so short sharp, precise bursts work best.
There are some great vids on Youtube on undercoating.
BCC
https://bolterandchainsword.com/topic/291793-soft-primer/#findComment-3704583
Thanks for the tips, all. To answer some questions: I've tried all kinds of things but in this particular case...
I am not in the habit of washing models up, but I don't really work with resin. Maybe I'll give that a try with a couple remaining bits. I've heard it a million times and, like a teenager, thought that would never happen to me. :P I'm using Vallejo Air black surface primer through an airbrush, indoors at normal room temp, at what I'd consider the perfect spray distance. I cut the primer about 60/40 with water being the lesser, as it seemed a bit thick to push through. I also upped the pressure on the gun to about twice what I normally spray at. My cheap airbrush isn't really cutting it for me and I think I need an upgrade, although I don't think that's the culprit here. When it does spray, it sprays just fine. It's going on damp but not soaking, and it's not too dry or dusty. In short, it looks great and I FEEL like I'm doing it right. It's just that after it dries, it acts just like any old paint on bare plastic. Isn't primer supposed to bite in and adhere better? Like, that's the whole point of it? :P
Maybe I'm just expecting it to do something different than what it is.
https://bolterandchainsword.com/topic/291793-soft-primer/#findComment-3704922
In that case I'd suggest diluting it with acrylic thinner rather than water. Any "bite" is going to come from the medium/solvent, and water won't be doing anything in that respect.
That's a great idea! I'll try that. Now I have to find some. Most art stores should have this, I should think.
https://bolterandchainsword.com/topic/291793-soft-primer/#findComment-3704942
Also very little experience with Airbrushes/Airbrushed primers, but if it's still not working out, maybe switch over to primer in a can? I've never had any problems with Duplicolor Sandable black primer. Has great coverage, goes on thin, and doesn't seem to have a problem being handled.
https://bolterandchainsword.com/topic/291793-soft-primer/#findComment-3705240
Sure you can. I do with all my Vallejo. It's the dropper part that comes out and have some tissue or something handy for any paint that escapes. Also means that any unused paint in your airbrush can be poured back in too.
Really? I need to look at the bottle more closely. Thanks!
https://bolterandchainsword.com/topic/291793-soft-primer/#findComment-3706401
Like everyone else said:
1) wash/rinse the models.  Dunk and agitate your sprues into a shallow pan with some dishwashing soap and water before you cut anything off them.  Be sure to rinse them too.
2) check spray distance and thinner medium.  Water and flow mediums may be undermining your adhesion. You will need to let the primer cure for 24-48 hours.
3) It will still rub off if you over-handle it/scrape it.  The real protection is going to come from gloss/matte varnishing, but it can really kill your subtle colors.
I use the grey Surface Primer from Vallejo straight from the 200ml bottle shot at 15-20 PSI with a Paasche Talon using a .38MM needle.  I have a small (standard) dropper bottle of the Vallejo Air Grey Primer (it is a dark grey compared to the Surface Primer) and I don't think it works as good as the Surface Primer. (links for reference, not necessarily an endorsement of those websites)
https://bolterandchainsword.com/topic/291793-soft-primer/#findComment-3709332
I use the Valeejo primers myself either through my airbrush and ocassionally brushed on if its not worth the trouble of getting the airbrush out.
Do you shoot them straight or cut them with something? What PSI do you normally use? And most importantly, do you ever have a problem with it going on soft or do you have any tricks?
https://bolterandchainsword.com/topic/291793-soft-primer/#findComment-3711782
