tjdudey Posted June 3, 2014 Share Posted June 3, 2014 Page 38 - Iron Priests, Servo-armReplace this entry with the following:Range S AP x2 1TypeMelee,Specialist Weapon,Unwieldy Does the change in the FAQ above mean all the iron priests attacks are now S8 AP1, so 3 on the charge? Im thinking an Iron priest on bike with 4 cyberwolves (155pts including a tooth necklace) makes for a pretty good close combat unit. 3x S8 AP1 attacks and 15 S4 Rending attacks on the charge is not to be sniffed at. Or have i misunderstood completely? Link to comment https://bolterandchainsword.com/topic/291850-iron-priest-in-faq/ Share on other sites More sharing options...
Max_Dammit Posted June 3, 2014 Share Posted June 3, 2014 Its just a powerfist, He has one wound and hits last , so he will be challenged to death, god I hate that rule. Link to comment https://bolterandchainsword.com/topic/291850-iron-priest-in-faq/#findComment-3705906 Share on other sites More sharing options...
Reede Posted June 3, 2014 Share Posted June 3, 2014 While I certainly did prefer it when it was just an Extra attack, I believe you are correct tjdudey, it now acts as a whole weapon profile. Max also has a point, you'll want to run him with some sort of other character or he will just be getting challenged out, still it's a bit better than a powerfist. that AP1 makes him a vehicle killer in close combat, and now that explodes is on a 7+ its much harder to get there. Link to comment https://bolterandchainsword.com/topic/291850-iron-priest-in-faq/#findComment-3706179 Share on other sites More sharing options...
Leif Bearclaw Posted June 3, 2014 Share Posted June 3, 2014 It's a specialist weapon, as is the Thunder Hammer he gets as standard. He still gets an additional attack this time for 2 ccws, so 3 normally, 4 on the charge . He also has a 2+ save, giving him reasonable protection from being challenged to death. Not terrible for the points imo, but elites is too busy as it is... Link to comment https://bolterandchainsword.com/topic/291850-iron-priest-in-faq/#findComment-3706188 Share on other sites More sharing options...
Nadir Posted June 3, 2014 Share Posted June 3, 2014 If it is like another power fist, so now he has got 2 specialist weapons: hammer and servo arm. So he got another attack with could be also a thinder hammer one, for additional spec.weapon:) Still not so good for 1W model Link to comment https://bolterandchainsword.com/topic/291850-iron-priest-in-faq/#findComment-3706191 Share on other sites More sharing options...
tjdudey Posted June 3, 2014 Author Share Posted June 3, 2014 I would probably only run it in a double FOC match, or if I was taking Wolf Guard as troops Link to comment https://bolterandchainsword.com/topic/291850-iron-priest-in-faq/#findComment-3706213 Share on other sites More sharing options...
Baulder Posted June 3, 2014 Share Posted June 3, 2014 I know this was discussed elsewhere, can'#t remember the outcome, but if I remember correctly on a thunderwolf the iron priest will be getting 4*str 10 on the charge. Not too shabby I'd say. Join a wolflord on thunderwolf with 2 fenrisian wolves and you're starting to get a decent sized unit (although wounds are thin on the ground). IP on TWM 4 Cyber WL on TWM with shield 2 Fenrisian Link to comment https://bolterandchainsword.com/topic/291850-iron-priest-in-faq/#findComment-3706291 Share on other sites More sharing options...
Oz of the North Posted June 3, 2014 Share Posted June 3, 2014 Though if you put him on a thunder wolf, he will be 2 wounds Link to comment https://bolterandchainsword.com/topic/291850-iron-priest-in-faq/#findComment-3706294 Share on other sites More sharing options...
DanPesci Posted June 3, 2014 Share Posted June 3, 2014 standard guy with a thunder hammer on a thunderwolf comes in cheaper and has 4 S10 attacks does he not also Im thinking an Iron priest on bike with 4 cyberwolves (155pts including a tooth necklace) makes for a pretty good close combat unit. 3x S8 AP1 attacks and 15 S4 Rending attacks on the charge is not to be sniffed at. dont have the codex to hand, but im pretty sure cyberwolves dont get rending, theyre just a slightly tougher version of fenrisian wolves?? Link to comment https://bolterandchainsword.com/topic/291850-iron-priest-in-faq/#findComment-3706308 Share on other sites More sharing options...
tjdudey Posted June 3, 2014 Author Share Posted June 3, 2014 i didn't realise that the mount gave you an extra wound. Is it not just +1 attack, strength and toughness? Link to comment https://bolterandchainsword.com/topic/291850-iron-priest-in-faq/#findComment-3706314 Share on other sites More sharing options...
Baulder Posted June 3, 2014 Share Posted June 3, 2014 standard guy with a thunder hammer on a thunderwolf comes in cheaper and has 4 S10 attacks does he not also Im thinking an Iron priest on bike with 4 cyberwolves (155pts including a tooth necklace) makes for a pretty good close combat unit. 3x S8 AP1 attacks and 15 S4 Rending attacks on the charge is not to be sniffed at. dont have the codex to hand, but im pretty sure cyberwolves dont get rending, theyre just a slightly tougher version of fenrisian wolves?? think so +1T and 4+ save if I remember correctly Though if you put him on a thunder wolf, he will be 2 wounds don't think they get a +1 wound, otherwise wolf lords would be W4 on a mount Link to comment https://bolterandchainsword.com/topic/291850-iron-priest-in-faq/#findComment-3706371 Share on other sites More sharing options...
Oz of the North Posted June 3, 2014 Share Posted June 3, 2014 I am pretty sure that all cyberwolves get is a higher ld and a 4+ save, and a thunderwolf mount gives +1 attack,strength,toughness and wound, along with rending. Wolf lords on mounts are 4 wounds, look at Canis he is 3 wounds when he is not a wolf lord and regular thunderwolves are 2 wounds. Link to comment https://bolterandchainsword.com/topic/291850-iron-priest-in-faq/#findComment-3706701 Share on other sites More sharing options...
Baulder Posted June 3, 2014 Share Posted June 3, 2014 The codex (pg 62) States that they get the unit type cavalry, +1S, +1T, +1A and rending. No additional wounds that I can see, or did I miss it in the FAQ? You're right on the cyber wolves they have higher leadership too and an additional attack Link to comment https://bolterandchainsword.com/topic/291850-iron-priest-in-faq/#findComment-3706817 Share on other sites More sharing options...
Valerian Posted June 3, 2014 Share Posted June 3, 2014 No additional Wound for Thunderwolf Mounts. Link to comment https://bolterandchainsword.com/topic/291850-iron-priest-in-faq/#findComment-3706934 Share on other sites More sharing options...
