badgermeister Posted June 4, 2014 Share Posted June 4, 2014 Fellow Servitors What set up are you currently using to kill primarchs at the 2k point? im looking at the cerastus knight as an option but not entirely sure I5 on the charge will make any difference. Perhaps 2 x venators would be a better option and even look at the option of 3 x venators? Close combat is hard to pull off at the cost efficiency end for points so im guessing firepower is the ony real option? Link to comment https://bolterandchainsword.com/topic/291953-primarch-killing-options/ Share on other sites More sharing options...
Nehekhare Posted June 6, 2014 Share Posted June 6, 2014 titans. Link to comment https://bolterandchainsword.com/topic/291953-primarch-killing-options/#findComment-3710881 Share on other sites More sharing options...
Kilofix Posted June 6, 2014 Share Posted June 6, 2014 Plasma, lots of Plasma. Link to comment https://bolterandchainsword.com/topic/291953-primarch-killing-options/#findComment-3710967 Share on other sites More sharing options...
badgermeister Posted June 7, 2014 Author Share Posted June 7, 2014 please note i said the 2000pts limit - i cant stick my warhound in until 3000pts regarding plasma its difficult to get lots when the options are thallax and myrmidon secutors. It turns out pretty expensive in points :( Most effective is probably the venator plasma fusil weaponry it has. Link to comment https://bolterandchainsword.com/topic/291953-primarch-killing-options/#findComment-3711410 Share on other sites More sharing options...
Kilofix Posted June 7, 2014 Share Posted June 7, 2014 Unfortunately I think you are stuck with: Secutors with Graviton or Plasma Ursarax with Volkite (Blast) Destructors with Graviton or Photon Thallax with their one Plasma, Photon or Multi-Melta Anything with AP2+ in volume. Otherwise maybe a Lightning with Kraken or Phosphex Link to comment https://bolterandchainsword.com/topic/291953-primarch-killing-options/#findComment-3711547 Share on other sites More sharing options...
Reclusiarch Darius Posted July 10, 2014 Share Posted July 10, 2014 You could tie one up for a while with this guy; Malagra Arch-Magos w/master-crafted paragon blade+chainfist, abeyant, machinator array, cyber-familiar, rad grenades, cyber-occularis (255 points) Paragon blade is for stabbing non-Primarch characters, obviously you'd just choose chainfist against a Primarch. They're at -1 Toughness, and you're a T6 W4 with 2+/3+ and IWND. Might rip half the wounds off a weaker one before you succumb. Link to comment https://bolterandchainsword.com/topic/291953-primarch-killing-options/#findComment-3741885 Share on other sites More sharing options...
Hyaenidae Posted July 11, 2014 Share Posted July 11, 2014 On 6/6/2014 at 10:13 PM, Nehekhare said: titans. On 6/6/2014 at 11:57 PM, Kilofix said: Plasma, lots of Plasma. Warhound with two Plasma Blastguns. Supported by another with the same armament. And two giant squads of Secutors to tarpit 'em. Link to comment https://bolterandchainsword.com/topic/291953-primarch-killing-options/#findComment-3742319 Share on other sites More sharing options...
Nehekhare Posted July 11, 2014 Share Posted July 11, 2014 Actually, eight myrmidon destructors with graviton imploders should be enough. Plasma Warhounds don't work, see Betrayer ;) Link to comment https://bolterandchainsword.com/topic/291953-primarch-killing-options/#findComment-3742408 Share on other sites More sharing options...
