a youtube channel
Guest mr boss man astra militari
Just a quick heads up.  If you are suggesting something, it might be a good idea to explain why you want it and what it would entail.  Just using 2 smileys doesn't make for a strong case.
Myself, I'm not sure what value a youtube channel would actually have when it relates to the B&C.
However, if you were to make a convincing case, then that might change things.
Note:  I have edited the title of this topic to comply with the B&C rules (found here) which expressly forbid the use of so-called leet-speak.
