Crazy Jay Posted June 7, 2014 Share Posted June 7, 2014 So I'm seeing that the CCB is going to be the go to Necron unit. The Necron player is coming around to them so I know I'll be facing them more often. So what's our best (C:DA only) option for dealing with it? Link to comment Share on other sites More sharing options...
Prot Posted June 7, 2014 Share Posted June 7, 2014 I actually play Necrons, and have used the CCB in 7th. The funny thing is the Destroyer Lord is probably better bang for the buck, because it's cheaper, can hide in a unit, and confer Preferred Enemy onto its unit (usually Wraiths). My advice would be to pour firepower into the unit because in close combat it is a beast. It's forte is survivability because the owning player gets to delegate shooting wounds to either the Lord or the Barge. It will most likely also feature a 3+ invulnerable and Mind Shackle Scarabs and a Scythe. So I'd stay away from it in close combat unless you can simply tarpit it.... if you have to go toe to toe with it, probably good old Hammer/Shield guys or Deathwing Knights as a second option. In close combat you can dictate where the wounds are allocated (the rider or the ride). *Note: the way I play a command barge is it cannot join a unit. Some people are claiming RAW allows it to join (non-vehicle) squads. *Note 2: Mind Shackle Scarabs did get an indirect minor nerf. Since you keep your models where they were during a challenge now, targeting a challenged character for Mind Shackle is nearly impossible since you are still in close combat with some of the other squad members and Mind Shackle is random. Link to comment Share on other sites More sharing options...
Crazy Jay Posted June 10, 2014 Author Share Posted June 10, 2014 Thanks for the reply. Something I found is that template and blast attacks always go to the chariot. The Vindicator sounds like a good solution. Link to comment Share on other sites More sharing options...
