Spartan Assault Tank directions
thepager
Hello everyone,
Recently acquired the parts for a Spartan Assault tank, SUPER EXCITED. However, I would love if someone could scan a copy of the instructions or something because I am hesitant to build it without it. It would definitely make things easier. Thanks in advance!!
https://bolterandchainsword.com/topic/292155-spartan-assault-tank-directions/
Step 1 Clean and prepare model.
Step 2 Start putting the hull together, notice the bottom plate is a bit warped. Straighten it out with hot water while thinking this isn't to bad to build.
Step 3 Try and connect the sides to the hull, notice the gaps and start to swear a bit.
Step 4 Try and fit the tracks. Stop, flip out and rage quit the hobby,
There we go, all clear now?
yes I had particular problems with the tracks, seemed to be more tracks than room to put them, took quite a bit of tinkering to get them to fit so I guess be aware of that possibility, as I've noticed this mentioned before by others as well. but good luck with it.
