chosen40k Posted June 14, 2014 Share Posted June 14, 2014 Specifically these ones: http://www.forgeworld.co.uk/The_Horus_Heresy/Legiones_Astartes/Iron_Hands/IRON_HANDS_LEGION_HEADS_UPGRADE_SET.html http://www.forgeworld.co.uk/New_Stuff/IMPERIAL_FISTS_MK_III_HEAD_UPGRADE.html Thank you! Link to comment https://bolterandchainsword.com/topic/292441-are-the-mkiii-heads-compatible-with-the-gw-tactical-squad/ Share on other sites More sharing options...
Pyromancer Posted June 14, 2014 Share Posted June 14, 2014 I'd say yes. They are a little bit bit bulky because they have additional armour plates over the regular, but they don't look out of place, in fact they look quite brutal! I believe the Imperial Fists ones are a slight bit thinner than the IH ones, although that is merely a guess on my part! Link to comment https://bolterandchainsword.com/topic/292441-are-the-mkiii-heads-compatible-with-the-gw-tactical-squad/#findComment-3718295 Share on other sites More sharing options...
Grotsmasha Posted June 14, 2014 Share Posted June 14, 2014 They sure are, I'll post a pic in awhile. The only torso they don't work with is the mkVIII torso's as they have the raised forget. Cheers, Jono Link to comment https://bolterandchainsword.com/topic/292441-are-the-mkiii-heads-compatible-with-the-gw-tactical-squad/#findComment-3718344 Share on other sites More sharing options...
