Jolemai Posted June 16, 2014 Share Posted June 16, 2014 Do you actually think the +1A with a DCCW is better than a Frag Cannon in this fight? Link to comment https://bolterandchainsword.com/topic/292483-imperial-knight-army-insert-explicative-of-your-choice/page/2/#findComment-3720307 Share on other sites More sharing options...
Demoulius Posted June 16, 2014 Share Posted June 16, 2014 Do you actually think the +1A with a DCCW is better than a Frag Cannon in this fight? I would think so.... Frag cannon can only damage their rear (I assume?) whilst the DCCW is a major threat even on the front Link to comment https://bolterandchainsword.com/topic/292483-imperial-knight-army-insert-explicative-of-your-choice/page/2/#findComment-3720315 Share on other sites More sharing options...
Jolemai Posted June 16, 2014 Share Posted June 16, 2014 It's a whopping +1A at the same initiative as the Knight, with irrelevant ranged weaponry (considering you've already got one Blood Fist with a Melta Gun). With the Frag Cannon (which in an ideal world is either behind or to the side), you get two shots with Rending which should cause some damage (unless Rending has been changed this edition) and, shooting caused zero damage to your Dreadnought. Point is, at best you're likely to cause more damage - even if it's just hit point removal - than +1A in combat, no? Link to comment https://bolterandchainsword.com/topic/292483-imperial-knight-army-insert-explicative-of-your-choice/page/2/#findComment-3720323 Share on other sites More sharing options...
Morticon Posted June 16, 2014 Share Posted June 16, 2014 Rear and side armour is 12? So, its hope for a 6 on 2 rolls (ie: 33% of an AP- pen, and that's not counting the shield since you're unlikely to get rear armour without a pod). - or - 43% chance of an AP2 pen (and +-58% chance of at least a glance) Id go for the extra attack in this case. Unless it was a drop dread. Magna grapple wouldnt be a bad idea though! Link to comment https://bolterandchainsword.com/topic/292483-imperial-knight-army-insert-explicative-of-your-choice/page/2/#findComment-3720345 Share on other sites More sharing options...
Jolemai Posted June 16, 2014 Share Posted June 16, 2014 13/12/12 Ion Shield would likely cover the front armour unless a) something nasty is elsewhere or b) you have nothing to threaten the front with imo. Link to comment https://bolterandchainsword.com/topic/292483-imperial-knight-army-insert-explicative-of-your-choice/page/2/#findComment-3720353 Share on other sites More sharing options...
Demoulius Posted June 16, 2014 Share Posted June 16, 2014 Point is your odds are alot greater with the fist, which would make him ALOT bigger threat to knights. Thanks to Jolemai for giving us the armour values, I was actually making this decision with AV10 rear into consideration.... (bad scatter would mean youd hit more heavily armoured side etc) Even when your in his rear youd need an AP roll of 6 to do damage with the template. With the fist an AP roll of 3 does damage. Quite a significant difference :) Link to comment https://bolterandchainsword.com/topic/292483-imperial-knight-army-insert-explicative-of-your-choice/page/2/#findComment-3720506 Share on other sites More sharing options...
librisrouge Posted June 16, 2014 Share Posted June 16, 2014 The fist is great...if you're tailoring for the Knight and not going "all comers" where the Frag Cannon is kind. I'd probably keep the Frag Cannon. If you want Dreadnoughts to take this thing out then you needed it to be weakened to begin with or to have multiple Dreadnoughts charge it. Link to comment https://bolterandchainsword.com/topic/292483-imperial-knight-army-insert-explicative-of-your-choice/page/2/#findComment-3720708 Share on other sites More sharing options...
Chaplain Admetus Posted June 16, 2014 Share Posted June 16, 2014 Another potential thing to bear in mind is weapon destroyed results. If you have the frag cannon, a weapon destroyed result can potentially rip off the only blood fist arm and leave you a bit screwed. Fliers are definitely the best bet though as Knights aren't so hot against them - pretty sure they can't actually touch a Storm Raven with any of their guns unless you hover. I assume that's why he brought the Stormwing formation, though that seems like a large amount of points. Link to comment https://bolterandchainsword.com/topic/292483-imperial-knight-army-insert-explicative-of-your-choice/page/2/#findComment-3720730 Share on other sites More sharing options...
Nova_chron Posted June 17, 2014 Author Share Posted June 17, 2014 Knights can snap fire heavy stubbers at your fliers and yeah his storm wing was to fight my raven. Also each assault squad was packing 5 melta shots between the melta guns dual infernus sarge and an infernus wielding priest. Link to comment https://bolterandchainsword.com/topic/292483-imperial-knight-army-insert-explicative-of-your-choice/page/2/#findComment-3721005 Share on other sites More sharing options...
Morticon Posted June 17, 2014 Share Posted June 17, 2014 Knights can snap fire heavy stubbers at your fliers and yeah his storm wing was to fight my raven. Also each assault squad was packing 5 melta shots between the melta guns dual infernus sarge and an infernus wielding priest. Heavy stubbers are of zero concern. They're S4 shots. The Storm Wing is trickier -you defs need more than one raven, and you need to go second to react to his. As for the assault squad - was that yours or his? If yours, its quite nice to take on a Knight. If its his, only if he's lucky he will get 1 hit against a flyer, and then its a 50% chance of doing something and a 33% chance of getting a pen - remember the ceramite rule!! With POTMS you can take down two storm talons a turn with one raven, leaving the other one to focus on his raven. Link to comment https://bolterandchainsword.com/topic/292483-imperial-knight-army-insert-explicative-of-your-choice/page/2/#findComment-3721057 Share on other sites More sharing options...
Nova_chron Posted June 17, 2014 Author Share Posted June 17, 2014 The ASM were my squads Link to comment https://bolterandchainsword.com/topic/292483-imperial-knight-army-insert-explicative-of-your-choice/page/2/#findComment-3721475 Share on other sites More sharing options...
