Jamafore Posted June 16, 2014 Share Posted June 16, 2014 I just started assembling a Stormtalon. The instructions say to put the arms on after I put the outer fuselage on. To have more room to paint it, can I put the arms on before that? It looks like the control panel has to go on after the fuselage, but I figure while positioning the arms I could balance the panel on the pilot's lap. Link to comment https://bolterandchainsword.com/topic/292519-question-about-assembling-the-stormtalon-cockpit/ Share on other sites More sharing options...
Jeff Newton Posted June 16, 2014 Share Posted June 16, 2014 There are little tabs around the feet that are from the fuselage that I had to trim off to get my cockpit in since I painted that up first. Once the cockpit and pilot were together and painted that was the only problem I had with assembling and painting. Link to comment https://bolterandchainsword.com/topic/292519-question-about-assembling-the-stormtalon-cockpit/#findComment-3720191 Share on other sites More sharing options...
Jamafore Posted June 17, 2014 Author Share Posted June 17, 2014 Ok Thank you. Link to comment https://bolterandchainsword.com/topic/292519-question-about-assembling-the-stormtalon-cockpit/#findComment-3721911 Share on other sites More sharing options...
