Quixus Posted June 18, 2014 Share Posted June 18, 2014 IRL shells and missiles are often color coded to differentiate the payloads. Do you do that with the misiles in the CML or on devastators as well? What would appropriate colors be for frag and krak missiles? How would you arrange them in the CML? Link to comment https://bolterandchainsword.com/topic/292659-missile-color-codes/ Share on other sites More sharing options...
Dam13n Posted June 18, 2014 Share Posted June 18, 2014 I pick two colours that suit the scheme of the models as a whole. Though Red/Yellow are favourites. Organisation: Frag Krak Frag - Frag Krak Frag Krak Frag Krak - Krak Frag Krak Link to comment https://bolterandchainsword.com/topic/292659-missile-color-codes/#findComment-3722605 Share on other sites More sharing options...
Ovidius Incertus Posted June 18, 2014 Share Posted June 18, 2014 I might go with black tips for krak, as black is the AP tip color for 50 BMG rounds in US military logistics (and I think UK too). Frag is more open: for various HE-type munitions out there, you get white tips, blue tips, and sometimes yellow tips, depending on who, what and when. The US SMAW, which may be a good analogue for a frag missile, has a base metal tip with a yellow band around it. How you arrange them in a rack is up to you. I've seen images of FFAR rocket pods loaded apparently willy-nilly. Link to comment https://bolterandchainsword.com/topic/292659-missile-color-codes/#findComment-3722608 Share on other sites More sharing options...
averykess Posted June 18, 2014 Share Posted June 18, 2014 I paint all the tips poking out the Cyclone and Whirlwind the same, since most of the markings are on the middle of the munition. I did find this: http://www.alternatewars.com/BBOW/Markings/MM2597_Interpreting_Ammunition_Markings.pdf Link to comment https://bolterandchainsword.com/topic/292659-missile-color-codes/#findComment-3722622 Share on other sites More sharing options...
reckoning Posted June 19, 2014 Share Posted June 19, 2014 I might go with black tips for krak, as black is the AP tip color for 50 BMG rounds in US military logistics (and I think UK too). Frag is more open: for various HE-type munitions out there, you get white tips, blue tips, and sometimes yellow tips, depending on who, what and when. The US SMAW, which may be a good analogue for a frag missile, has a base metal tip with a yellow band around it. How you arrange them in a rack is up to you. I've seen images of FFAR rocket pods loaded apparently willy-nilly. SMAW rockets are also encased in green, almost olive drab tubes which fit into the launcher itself. In combat you never actually see the rocket itself unless you catch a glimpse of it in flight. And the HEDP (High Explosive Dual Purpose), rocket casing has the same yellow band as the HEAA (High Explosive Anti Armor), rocket, two very different munitions. Link to comment https://bolterandchainsword.com/topic/292659-missile-color-codes/#findComment-3723177 Share on other sites More sharing options...
Iron Father Ferrum Posted June 19, 2014 Share Posted June 19, 2014 And besides, the last time I checked the one thing the Codex AStartes doesn't color-code for rapid recognition is munitions. So if you want to give them different tip-markings, the colors are up to you. Link to comment https://bolterandchainsword.com/topic/292659-missile-color-codes/#findComment-3723740 Share on other sites More sharing options...
Quixus Posted June 19, 2014 Author Share Posted June 19, 2014 Are the company colors and other color codes in the Codex? Woohoo for the micromanaging Robot Link to comment https://bolterandchainsword.com/topic/292659-missile-color-codes/#findComment-3723798 Share on other sites More sharing options...
Iron Father Ferrum Posted June 20, 2014 Share Posted June 20, 2014 They sure are. The book Insignium Astartes is about the most thorough explanation of Codex-dictated markings I've ever seen. It's actually a pretty good guide if you're a detailed-oriented person painting a codex-compliant chapter. . . which means it didn't help me very much. Link to comment https://bolterandchainsword.com/topic/292659-missile-color-codes/#findComment-3724198 Share on other sites More sharing options...
Hyaenidae Posted June 20, 2014 Share Posted June 20, 2014 Red= Krak Yellow = Frag Keep it simple and clean, and you really can't go wrong. :) Link to comment https://bolterandchainsword.com/topic/292659-missile-color-codes/#findComment-3724225 Share on other sites More sharing options...
reckoning Posted June 20, 2014 Share Posted June 20, 2014 Red= Krak Yellow = Frag Keep it simple and clean, and you really can't go wrong. I notice your Krak also has a larger band of black that the red band is painted on. Awesome. Link to comment https://bolterandchainsword.com/topic/292659-missile-color-codes/#findComment-3724228 Share on other sites More sharing options...
Hyaenidae Posted June 20, 2014 Share Posted June 20, 2014 I thought it helped it stand out a bit more. Thanks for the compliment. Link to comment https://bolterandchainsword.com/topic/292659-missile-color-codes/#findComment-3724229 Share on other sites More sharing options...
Dam13n Posted June 20, 2014 Share Posted June 20, 2014 I went for: http://i352.photobucket.com/albums/r358/MatthewDaunt/AoRDeathwingSquad3.jpg (It's an old WIP photo, but the missiles are finished in it.) Link to comment https://bolterandchainsword.com/topic/292659-missile-color-codes/#findComment-3724299 Share on other sites More sharing options...
reckoning Posted June 20, 2014 Share Posted June 20, 2014 Its nice to see people step away from the same old, "Missiles and rockets must always have red tips no matter their purpose," mindset. Off Topic - Were you going for a Carl Gustav look with that conversion Heathens, or do you just not like the generic SM ML? Link to comment https://bolterandchainsword.com/topic/292659-missile-color-codes/#findComment-3724303 Share on other sites More sharing options...
Quixus Posted June 20, 2014 Author Share Posted June 20, 2014 I think the style of the ML fits very well with the Iron Warriors. Hmm, the K F K K F K F K F F K Fdoes not look as "busy" as I thought. Initially I was torn beween K K K F F F K K K F F Fand K K K K K K F F F F F F Link to comment https://bolterandchainsword.com/topic/292659-missile-color-codes/#findComment-3724325 Share on other sites More sharing options...
Hyaenidae Posted June 24, 2014 Share Posted June 24, 2014 Off Topic - Were you going for a Carl Gustav look with that conversion Heathens, or do you just not like the generic SM ML? I'm aiming for more "dumbed down" tech in my army, so many of my heavier weapons are simplified for easy maintenance, construction, and survival in the soggy hell of a trench line. Thus, Panzershreck. Hell, wait til you see my "Rotor Cannons".... :lol: Link to comment https://bolterandchainsword.com/topic/292659-missile-color-codes/#findComment-3728331 Share on other sites More sharing options...
Quixus Posted June 24, 2014 Author Share Posted June 24, 2014 Hell, wait til you see my "Rotor Cannons".... M1917? Link to comment https://bolterandchainsword.com/topic/292659-missile-color-codes/#findComment-3728511 Share on other sites More sharing options...
