Nephilim As Thunderbolt
I'm struggling with anti-air at the moment and I'm thinking that the Thunderbolt is, point for point, a better deal than the Vendetta in that role. The biggest hurdle is price though. I simple cannot afford FW rates!
That got me thinking about conversions and the Dark Angel Nephilim sprang to mind. What do you guys think about using one, with some weapon swaps, as an Imperial Navy fighter?
https://bolterandchainsword.com/topic/292690-nephilim-as-thunderbolt/
I think it'd be fine if you can get the right weapons on, as a flyer it is less of an issue getting the exact right size of a counts as. I have seen neither model on the table top so I can't say if they're the approximate same size but it'd be a good opportunity to Guard it up. Emperor knows the kit could do with some sales from all I've heard...
Well, the do look similar, but I have never held a TB before, so I can not say how they compare is size. But, a bit off-topic, ever considered a Hydra? 2 of them squadronned costs 1 HS slot and 140 points. They can dakka fliers, skimmers, the occasional ground target and have plenty utility outside of dakka if you can think outside of the box.
I've played against a Thunderbolt a few times, and while I didn't have a Nephilim on the table to compare it with, my recollection is that it's close to a Stormraven in terms of size and bulk. Definitely a lot bigger than a Stormtalon.
A Nephilim's wings bulk it up a bit, but it would still look tiny next to the real thing.
In fact, here's a photo of a Thunderbolt with a squadron of Valkyries: http://4.bp.blogspot.com/-Dzm8cp29aAc/UC-81Ef5eiI/AAAAAAAAAaY/OIkwszBntWA/s1600/DSC09287.JPG
The Valkyrie is about as wide and long as a Stormraven, but much less bulky, so my memory seems to be sound.
Thanks for that Lucien and hendrik, that makes quite a difference! Looks like the Nephilim might be too small, so if you wanted to stick with it then you'd have to convert it somehow to bulk it out a bit. I'm unfamiliar with the kit so I don't know how easy that would be, so probably better to do hendrik's mod?
Sex.  That picture is pure sex!  I will soon have four valkyries and I already have an avenger...but that pic renews my resolve to get a pair of thunderbolts as soon as my ETL vows are finished...
