Marine Void Harness
Joeyray
Greetings Brethren,
Flicking through Know no Fear and I came upon Thiel and the void combat upon the starship hulls:
"The low gravity amplifies their strength. One firm step becomes a bound of ten metres. The practical takes a second to master, despite the hours of theoretical and drill. It is too easy to overstep, to push too hard, to fly too far. Across the wider gulfs, the ravines of the port-side cooling vents and the immense canyons of the interdeck crenellations, members of the kill squad switch to quick burns of their void-harnesses, clearing the divides of adamantium and steel chasms."
"They hard-burn with their void-harnesses, following the wide canyon of a brightly lit heat exchange channel, and passing under the stark shadow of a power coupling the size of a suspension bridge. Their tiny black shadows chase them along the hull."
Credit to Abnett for his work setting the scene, I always think of Moonraker's Space Laser Battle for inspiration, Now I sadly don't own any of the FW HH series but is their any expansion on the look of what a void harness would look like?
https://bolterandchainsword.com/topic/292846-marine-void-harness/
In the original fluff, power units did include thrusters - that's why we have what are exhaust pipes on the sides at the top. This is most obvious on the Mk IV power unit. That aside, I think jump packs would be over egging the pudding, as does it seems DA. So the idea of a less powerful and bulky void harness makes a lot of sense to me :)
They've retconned the backpacks multiple times. Originally they were "stabilising jets". Then they became exhausts, and the Chaos backpacks had them on stalks because they only had access to lower quality power plants in the Eye of Terror which generated more radiation/heat. Then Betrayal has a Death Guard Marine already with a Chaos-style backpack where they're jets again AND generate more radiation/heat.
