Kilofix Posted June 24, 2014 Share Posted June 24, 2014 Which GW Scenery kit can be used to build Necromunda'esq eleveted walkways like the following: http://www.ebay.com/itm/Wargames-Warhammer-40K-Necromunda-Scenery-Masive-Terrain-Set-/201079015626?pt=UK_Toys_Wargames_RL&hash=item2ed13e48ca I'm assmuning multiple sets of the Sanctum Imperialis and Landing Platform would be what's needed? Or, would the Basilica Administratum be better? Thanks for the opinions. Link to comment https://bolterandchainsword.com/topic/292886-which-gw-scenery-kit-for-elevated-walkways/ Share on other sites More sharing options...
Ovidius Incertus Posted June 24, 2014 Share Posted June 24, 2014 Does it have to be GW? That looks a lot like something from Pegasus Hobbies: http://pegasushobbies.net/catalog/Peg.-Gaming-Accessories/c2/index.html . Link to comment https://bolterandchainsword.com/topic/292886-which-gw-scenery-kit-for-elevated-walkways/#findComment-3727563 Share on other sites More sharing options...
Kilofix Posted June 24, 2014 Author Share Posted June 24, 2014 Does it have to be GW? That looks a lot like something from Pegasus Hobbies: http://pegasushobbies.net/catalog/Peg.-Gaming-Accessories/c2/index.html . Interesting - thanks! Still curious about the GW stuff though. Especially, which kits can build the stuff seen in 6h Ed. BRB Battles section. Link to comment https://bolterandchainsword.com/topic/292886-which-gw-scenery-kit-for-elevated-walkways/#findComment-3727585 Share on other sites More sharing options...
Gurth Posted June 24, 2014 Share Posted June 24, 2014 http://pegasushobbies.net/catalog/Peg.-Gaming-Accessories/c2/index.htmlThose are very good sets for SF wargaming terrain, especially because the parts are designed to click together and come apart again. I’d rate the Platformer as the better of the two, BTW, though it requires a little more work to make usable. Unfortunately the Hexagon and Platformer sets aren’t compatible with each other, and you want to stay away from the Chemical Plant — it’s compatible with (I think) Platformer, but there’s so bloody many parts in it that you’ll tire of it even before you’ve got them all from the sprues, never mind painted. Still curious about the GW stuff though. Especially, which kits can build the stuff seen in 6h Ed. BRB Battles section.Those all look like they were made from the various GW building kits released around the time of Cities of Death, plus landing pads and assorted other kits. Link to comment https://bolterandchainsword.com/topic/292886-which-gw-scenery-kit-for-elevated-walkways/#findComment-3727756 Share on other sites More sharing options...
WingsOfTheFalcon Posted June 24, 2014 Share Posted June 24, 2014 I've heard of people building them for Necromunda using the Modular Movement Trays. Link to comment https://bolterandchainsword.com/topic/292886-which-gw-scenery-kit-for-elevated-walkways/#findComment-3727878 Share on other sites More sharing options...
averykess Posted June 24, 2014 Share Posted June 24, 2014 The pictured auction is produced by the seller of that auction, Wargames Tournaments. It is all laser cut mdf from their mm Sci-Fi Industrial Terrain line. Trying to make something that covers the same amount of table with GW only parts would be much more expensive. Their website is: http://www.wargamestournaments.com/acatalog/Terrain_and_Scenery_.html Link to comment https://bolterandchainsword.com/topic/292886-which-gw-scenery-kit-for-elevated-walkways/#findComment-3727979 Share on other sites More sharing options...
SW1 Posted June 25, 2014 Share Posted June 25, 2014 The closest GWS stuff is the old necromunda bulkheads and thick card or 1.5mm plasticard. Link to comment https://bolterandchainsword.com/topic/292886-which-gw-scenery-kit-for-elevated-walkways/#findComment-3729317 Share on other sites More sharing options...
Seahawk Posted June 25, 2014 Share Posted June 25, 2014 - Support legs from the landing platform - Floors from any Citadel building - Parapets from any Citadel building And that's how you make it. :D Link to comment https://bolterandchainsword.com/topic/292886-which-gw-scenery-kit-for-elevated-walkways/#findComment-3729341 Share on other sites More sharing options...
Kierdale Posted June 26, 2014 Share Posted June 26, 2014 Yes, as Seahawk said. I think it's GW Metrocenter (up north in the UK) that has an underhive board ('Metromunda', naturally) made from all the various GW buildings and uses a lot of landing pads as junctions, and their support legs holding everything up. They did something similar to recreate Space Hulk boards too. Photos should be in their FB Gallery. Link to comment https://bolterandchainsword.com/topic/292886-which-gw-scenery-kit-for-elevated-walkways/#findComment-3729597 Share on other sites More sharing options...
Kilofix Posted June 26, 2014 Author Share Posted June 26, 2014 Anyone know which Citadel building has the most 'floors'? Thanks! Link to comment https://bolterandchainsword.com/topic/292886-which-gw-scenery-kit-for-elevated-walkways/#findComment-3729630 Share on other sites More sharing options...
treadhead Posted June 26, 2014 Share Posted June 26, 2014 department of outrageous pricing and on a slightly less humourous (but more on topic) note i'd have to say the sector house (assuming availabitlity is the best bet for price as i think it's 3 or 4 boxes worth Link to comment https://bolterandchainsword.com/topic/292886-which-gw-scenery-kit-for-elevated-walkways/#findComment-3729635 Share on other sites More sharing options...
Gurth Posted June 26, 2014 Share Posted June 26, 2014 Anyone know which Citadel building has the most 'floors'? Thanks!If you want lots of textured floors, you’d be better off using either one of the Hexagon/Platformer sets, or buying plastic card that comes with tiles already engraved on it — Evergreen, for one, sells this, and if it’s too thin for your needs, just laminate it with thicker, plain plastic card. For the price of one GW building kit you can probably cover a moderate-sized room's floor in plastic card. Link to comment https://bolterandchainsword.com/topic/292886-which-gw-scenery-kit-for-elevated-walkways/#findComment-3729803 Share on other sites More sharing options...
averykess Posted June 26, 2014 Share Posted June 26, 2014 Anyone know which Citadel building has the most 'floors'? Thanks!If you want lots of textured floors, you’d be better off using either one of the Hexagon/Platformer sets, or buying plastic card that comes with tiles already engraved on it — Evergreen, for one, sells this, and if it’s too thin for your needs, just laminate it with thicker, plain plastic card. For the price of one GW building kit you can probably cover a moderate-sized room's floor in plastic card. The Evergreen 1/2" Square Tile sheets would make great techno walkways. The sheets come 6" x 12". Snap them apart into 2" wide strips and you have 36" of walkway for ~$6.59. dress it up with some sides/edges and maybe some structure and supports underneath. Link to comment https://bolterandchainsword.com/topic/292886-which-gw-scenery-kit-for-elevated-walkways/#findComment-3730070 Share on other sites More sharing options...
