Knight of the Raven Posted June 25, 2014 Share Posted June 25, 2014 I bought one pot when it first came out and it dried up within one week. How can I avoid this happening again? Link to comment https://bolterandchainsword.com/topic/292951-question-about-liquid-green-stuff/ Share on other sites More sharing options...
JeffTibbetts Posted June 25, 2014 Share Posted June 25, 2014 You mean dried completely? Mine is a bit drier than when I bought it, but I think it actually works better for me this way. It's more like a paste that you scoop on as opposed to something you'd try to brush on. I think the idea came to me from the new GW sculpting tools, with the plastic shovel end. They recommend using it for LGS and texture paint. I've had some success with using LGS like that, almost like a spackling compound. I scoop it on with the blade of my hobby knife and then scrape across the surface with same. If it completely dried up, you got a bad pot or something. Link to comment https://bolterandchainsword.com/topic/292951-question-about-liquid-green-stuff/#findComment-3729074 Share on other sites More sharing options...
Knight of the Raven Posted June 25, 2014 Author Share Posted June 25, 2014 Yep, dry as a desert. I know leaving superglue out of the sunlight (and even into a fridge) helps making it last longer, would the same apply to liquid green stuff? Link to comment https://bolterandchainsword.com/topic/292951-question-about-liquid-green-stuff/#findComment-3729082 Share on other sites More sharing options...
averykess Posted June 25, 2014 Share Posted June 25, 2014 I absolutely hate liquid green stuff. I got a bottle when it first came out, I think it is still good. I've used it twice. The real problem I have with LGS is that is sands like crap. Regular Green Stuff is great for building detail in, but for gap/seam filling, go for a putty. I get much better results with Squadron Green Putty thinned with a bit of acetone or Tamiya white putty. Of course you have to be willing to work with slightly flammable/hazardous materials, but that is usually the case if you want the good results. PM me your address if you are in the US, I'll send you my bottle of LGS if it is still good (I'll have to check). Link to comment https://bolterandchainsword.com/topic/292951-question-about-liquid-green-stuff/#findComment-3729236 Share on other sites More sharing options...
JeffTibbetts Posted June 25, 2014 Share Posted June 25, 2014 I absolutely hate liquid green stuff. I got a bottle when it first came out, I think it is still good. I've used it twice. The real problem I have with LGS is that is sands like crap. Regular Green Stuff is great for building detail in, but for gap/seam filling, go for a putty. I get much better results with Squadron Green Putty thinned with a bit of acetone or Tamiya white putty. Of course you have to be willing to work with slightly flammable/hazardous materials, but that is usually the case if you want the good results. PM me your address if you are in the US, I'll send you my bottle of LGS if it is still good (I'll have to check). I also use Tamiya putty which is great for sanding and stuff. My only gripe is that it's a bit too sticky and loose, so it can be hard to get it where I want it. In areas that are tough to sand it's not the best option, I've found. Is that Squadron stuff maybe a good alternative for these situations? Link to comment https://bolterandchainsword.com/topic/292951-question-about-liquid-green-stuff/#findComment-3729261 Share on other sites More sharing options...
CoffeeGrunt Posted June 25, 2014 Share Posted June 25, 2014 My pot's still good. Have yet to find a decent use for the stuff, but it's still liquid. Link to comment https://bolterandchainsword.com/topic/292951-question-about-liquid-green-stuff/#findComment-3729284 Share on other sites More sharing options...
averykess Posted June 25, 2014 Share Posted June 25, 2014 I absolutely hate liquid green stuff. I got a bottle when it first came out, I think it is still good. I've used it twice. The real problem I have with LGS is that is sands like crap. Regular Green Stuff is great for building detail in, but for gap/seam filling, go for a putty. I get much better results with Squadron Green Putty thinned with a bit of acetone or Tamiya white putty. Of course you have to be willing to work with slightly flammable/hazardous materials, but that is usually the case if you want the good results. PM me your address if you are in the US, I'll send you my bottle of LGS if it is still good (I'll have to check). I also use Tamiya putty which is great for sanding and stuff. My only gripe is that it's a bit too sticky and loose, so it can be hard to get it where I want it. In areas that are tough to sand it's not the best option, I've found. Is that Squadron stuff maybe a good alternative for these situations? You'll need to thin the Squadron stuff with a tiny bit of acetone, but you can control how liquid it gets. Tamiya grey putty is better than the white. Aves Apoxie is supposed to be awesome, but I haven't gotten any yet. Link to comment https://bolterandchainsword.com/topic/292951-question-about-liquid-green-stuff/#findComment-3729351 Share on other sites More sharing options...
Forté Posted June 27, 2014 Share Posted June 27, 2014 Mine went quite dry quickly. Stuff is a pile of :cuss I hear Vallejo Plastic Putty is better but I've not tried it. Link to comment https://bolterandchainsword.com/topic/292951-question-about-liquid-green-stuff/#findComment-3731515 Share on other sites More sharing options...
