Thanatar Siege Automata Up
Here it is!
http://www.forgeworld.co.uk/Images/Product/DefaultFW/large/thanatar1.jpg
The Thanatar is a heavy Siege-automata, designed as a mobile artillery platform rather than a general battle unit. It is armed with a Hellex pattern plasma mortar, a terrifying weapon able to launch dense spheres of blazing plasma on arcing trajectories over defensive barriers and into the heart of enemy fortifications, incinerating anything in their blast radius with a liquid tide of sun-hot fire.
The Thanatar’s frame, built to accommodate the huge weapon and the power systems and fuel reserves required to supply it, is considerably larger than even the hulking Castellax. Its frame is also heavily reinforced, both to withstand the stresses of firing its principal weapon and protect it from incoming attacks. This factor, alongside the use of an atomantic shielding array, make Thanatars notoriously durable. Such is their resilience that Thanatars are beyond the ability of most small arms, no matter how advanced, to harm.
The Thanatar Seige-automata is a complete multi-part resin kit, designed by Will Hayes. This model is available to pre-order now and will be despatched from Monday 30th June.
https://bolterandchainsword.com/topic/292992-thanatar-siege-automata-up/
I'm still trying to figure out how you "lob" a sphere of plasma, since an ionized gas cloud isn't going to have enough mass to actually follow a ballistic arc short enough to be tactically useful.  Gorgeous model, though.
Think it's like the plasma from Starship troopers.
Plasma weapons 'frame' the raw material in magnetic fields as they build up to release, containing and shaping the energy into 'bolts' when they fire along the magnetic accelerators (those annoying-to-paint coils along the gun's spine). So, it's like... a projectile of shaped plasma, with weight and mass and oh God my head.
Here it is!
Just look at that thing. That's what happiness looks like, rendered in resin.
The physics of plasma weapons are best not thought about.  As far as a plasma mortar goes though, the actual mass of the projectile is pretty much irrelevant.  Gravity works based on the mass of the two objects that are involved, so in most cases what you're going to have is the mass of the planet dominating by many orders of magnitude.  So a ballistic arc would be doable.
Now the low mass of the plasma would be an issue if firing in a strong wind.
It'll have an arc, but the landing point would be somewhere in another hemisphere.  I'd much rather think of the Hellax as being in a stowed position behind the torso, rotating forward to fire directly.
Lets not start thinking about the issue caused by the recoil of a BFG mounted on the top of a bipedal war machine.
And really, the mass of the projectile is so minor that you don't have to think about it when working at the distances a mortar would be firing.  The M19 lobs its shell at 168m/s, this super plasma death mortar can do about the same and work like a charm.  Projectile mass only really needs to be accounted for when dealing with wind resistance.
And let's face it guys, SCI-FI world and miniature wargaming, who cares about physics with a model like that :).
