C:GK Inq Psykers
Gaz1858
It wont be in the BRB as that just lists all the powers available for every faction, and may well change in the future when a new codex is released. Check the FAQ for any changes. They can all be found here.
Currently we get access to Santic, Divination, Pyromancy, Telekinesis and Telepathy. Funnily enough no FAQ is out for the digital inquisition codex but I would imagine they have the same changes.
Thanks Quozzo,
Do Inquisitors come under the "Psykers" section of the FAQ then as Inquisitors themselves are not included afaik.
This sheet showed Inquisition as having access to all powers. If you type "Psychic power reference card" into google you will see what i mean.
Should the same list be used for the Forge World psykers
That's certainly the safe route, and definitely what I'd do.  Now, there is nothing out there that I'm aware of that explicitly tells you to do this, but it's still likely the most proper thing to do, and the thing which helps make the game work, rather than the thing that breaks the game.
V
Ah, yes, misread, sorry. Just go with the same list that all of the other primary Psykers get: Sanctic Daemonology, Divination, Pyromancy, Telekinesis, and Telepathy.
V
You didnt mis-read, it just wasn't specified so I had to cover both. The joys of having two codices in one forum biggrin.png
