FishFuzz99 Posted June 30, 2014 Share Posted June 30, 2014 I'm in the process of assembling a vindicator. I noticed that I have all the parts to make it into a rhino and I was wondering if it is worth the trouble to magnetize it so that I can switch it between the two. Do Blood Angels use rhinos all that often? I was considering doing the same for my razor back and or Baal predator. Link to comment Share on other sites More sharing options...
Emperors Immortals Posted June 30, 2014 Share Posted June 30, 2014 I use rhinos extensively, the fast engines on ours makes them absolutely worthwhile. Link to comment Share on other sites More sharing options...
shaun03 Posted June 30, 2014 Share Posted June 30, 2014 its always beneficially to magnetize units two units for price of one and is good force multiplier Link to comment Share on other sites More sharing options...
SonOfThunder Posted June 30, 2014 Share Posted June 30, 2014 You can magnetize it to also double as a razor, whirlwind or predator, so you can just buy the pieces from ebay and use a single chassis as any rhino variant. That way you can play fully mechanized infantry one day, then jump infantry with tank support the next. Link to comment Share on other sites More sharing options...
marine7312000 Posted July 1, 2014 Share Posted July 1, 2014 I have two rhinos that can easily be turned into Razorbacks by simply adding the top plate and guns. This tutorial on From The Warp goes into magnetizing the Rhino STC in depth: http://fromthewarp.blogspot.com/2010/03/magnetising-space-marine-stc-part-1-of.html Link to comment Share on other sites More sharing options...
Morticon Posted July 1, 2014 Share Posted July 1, 2014 Defs do it!! Two for one, matey. You wont be sorry. More options are always better than less options :D Link to comment Share on other sites More sharing options...
FishFuzz99 Posted July 1, 2014 Author Share Posted July 1, 2014 I did end up magnetizing it. I had already glued the armored side panels on so it doesn't have the side access points but that's not a big deal imo. I also managed to block where you put the turret pivot so I guess I'll have to just glue the turret mount on. Link to comment Share on other sites More sharing options...
Demoulius Posted July 1, 2014 Share Posted July 1, 2014 Personally couldnt be arsed (and still cant) to magnetize my vehicles but can see the merit behind it :) All my vehicles have personalities and identities of their own :D its the other side of the coin I guess. On the other hand it also costs more money and space to store them. Link to comment Share on other sites More sharing options...
