collecting the sons of russ
ZONKEY
Do you mean the Battleforce?
If so, Id say maybe. If you want to run pods, then probably. Thing is, Scouts aren't very good, so depending on the savings vs buying it all separately, there may be little point (haven't crunched the numbers recently myself) if the savings aren't more than the cost of the scouts.
Well if you're planning on using everything in the box, it's a bit of a no brainier.
But, although Scouts can to outflanking anti-tank duty, with a melta and a couple of plasma pistols max they're not fantastic at it. Suicide WG with combi meltas would work better. Or even a Dreadnought in a Drop Pod. It's a shame, I loved my Scouts under 5th, but they're not worth their points any more imo.
