greendestiny Posted July 3, 2014 Share Posted July 3, 2014 I am working on a Yarrick conversion but I need a few bitz of help. (pun intended) I have the basic model put together, the part that is eluding me is the small power backpack that he wears to support the powerclaw. So I am wondering what options you suggest for a powerpack? The only thing I had thought of so far was chopping up a Vox unit and running power cables to the powerclaw. Ideally I would like to get 4-5 of these so that I can do multiple builds/poses for the old man. I think this is a very fitting project considering the orks will be surging onto tabletops with the new codex coming out. comments/suggestions welcome. Link to comment https://bolterandchainsword.com/topic/293266-commissar-yarrick-conversion/ Share on other sites More sharing options...
Kierdale Posted July 3, 2014 Share Posted July 3, 2014 I think a vox unit (either the top or bottom half would suffice, considering the size of the power pack on the power-fist-and-book commissar) would suffice. You could always try chopping down a marine backpack but I honestly think the vox would look best. One last idea: a cut-down Scion backpack? Link to comment https://bolterandchainsword.com/topic/293266-commissar-yarrick-conversion/#findComment-3735659 Share on other sites More sharing options...
Sheesh Mode Posted July 3, 2014 Share Posted July 3, 2014 Wire and greenstuff around that wire, then use a sculpting tool to add rivets. OR! get actual metal wires from various hobby stores or rip them out of old technology and bend and cut to your purposes. Primer does wonders to mask what you've used. Link to comment https://bolterandchainsword.com/topic/293266-commissar-yarrick-conversion/#findComment-3735660 Share on other sites More sharing options...
greendestiny Posted July 3, 2014 Author Share Posted July 3, 2014 Good ideas guys. I hadn't thought of the Scion's backpack. I have guitar wire and greenstuff ready to go so between all of that I should be able to put something together. Okay this is an edit but I just looked over the Scion bits and I think that is the best option. If I chop off the bedroll of one of the normal guys or take off the antenna on the vox unit either is perfect size..... SO excited thanks for the help. Link to comment https://bolterandchainsword.com/topic/293266-commissar-yarrick-conversion/#findComment-3736334 Share on other sites More sharing options...
Kierdale Posted July 4, 2014 Share Posted July 4, 2014 Be sure to post photos, greendestiny. :) Link to comment https://bolterandchainsword.com/topic/293266-commissar-yarrick-conversion/#findComment-3736362 Share on other sites More sharing options...
greendestiny Posted July 10, 2014 Author Share Posted July 10, 2014 Sorry guys, I tried to link in a photo but every time I try the webpage freezes. ++ Here, let me get that for you ++ Thanks Grot!! I even tried to read the directions! You ROCK! Same mini with base colors only, no highlights or shading. Link to comment https://bolterandchainsword.com/topic/293266-commissar-yarrick-conversion/#findComment-3741289 Share on other sites More sharing options...
greendestiny Posted July 16, 2014 Author Share Posted July 16, 2014 Although still not completed I wanted to show an image of my Yarrick and his IG troops basic colors. Link to comment https://bolterandchainsword.com/topic/293266-commissar-yarrick-conversion/#findComment-3746276 Share on other sites More sharing options...
