Logan Grimnar
grum88
Interesting!
Would not be surprising at all.
The model isn't that new, rumour is he's being 'upgraded' to a lord of war (whether anything will change for his other rules remains to be seen) and he is leading the main SW contingent in Sanctus Reach. I can totally imagine him getting a new model.
That said, it could easily mean nothing.
https://bolterandchainsword.com/topic/293618-logan-grimnar/#findComment-3742331
Interesting!
Based on Ghazkull, I'd highly doubt he'll get new rules.
https://bolterandchainsword.com/topic/293618-logan-grimnar/#findComment-3742361
Its basically another FoC slot, with one LoW per Combined Arms detachment.
Thing is, if they're going the way of making the 200+ point special character a LoW without significant buffs is essentially wasting the slot, because they're competing with things super heavies.
https://bolterandchainsword.com/topic/293618-logan-grimnar/#findComment-3742477
fair enough, I'd thought there were some other super awesome reasons for taking a LOW other than flattening 1 unit per turn. Does seem a bit off to make certain ICs LOWs tho when the rest of them are thunderhawks/baneblades etc. Who knows, maybe there is a method to this madness.
https://bolterandchainsword.com/topic/293618-logan-grimnar/#findComment-3742509
A character using up a LoW slot does not make sense at the moment. If I am going to use the slot then it's going to be something worthy of the title. If Logan gets LoW without any significant advantage or formation then he will see a lot of shelf time. It is too bad because I like the old guy!
https://bolterandchainsword.com/topic/293618-logan-grimnar/#findComment-3742581
Agreed!! If the old wolf becomes a Lord of War, then 1. we better get a NEW MODEL!! He's smaller than the other termis from our TDA kit!! and 2. he better get a stat increase. I think an additional wound is manditory, and another point of toughness because, well the old man is as tough as nails!!
...oh and a NEW MODEL!!
End of Line
p.s. Skeletoro you got my hopes up!! You best be right, friend!! ;)
https://bolterandchainsword.com/topic/293618-logan-grimnar/#findComment-3742593
Keep in mind that Logan will be a lord of war
In fairness, we don't actually know that; it's just what some folks are assuming, based on Ghazkull's slot movement. Personally, I'd expect a Bjorn LoW to be more likely than Logan (although they could move both). Until we start hearing more about this from some of the more reliable rumor folks, I wouldn't state it as fact.
this will be quite a novice question but what does being a LOW really mean. I don't have the rulebook to hand and have never needed to look up the rules as I've never played escalation.
Nothing really, unless you and your opponent actually chose to play Escalation, in which case there are a few new rules for LoW play. Otherwise, it just frees up an HQ slot, but we've had 4x slots for the past 6 years, so we don't have the HQ slot pressure that other armies have. Who knows, however, if we'll keep that double the HQ feature in our upcoming codex, though. I suspect that we will (the Orks got 3 HQ slots in their new dex), but you never know until you see it in writing.
And now we have unbound, we don't need him as a reason to take an all wolf guard army any more.
Unless he made that same army battle forged.
It is possible that he'll lose his ability to make Wolf Guard Troops choices. Again, just making some assumptions based on the Ork codex, special characters that manipulate the FOC might be going the way of the dodo bird, in favor of special Formations and Unbound. I wouldn't be surprised, however, if Logan gets a special all-Wolf Guard Formation though.
V
If he is going to a LoW would that mean that we cant ever use him as HQ?
Correct, if he becomes LoW, he becomes LoW.  He won't be an HQ option.
https://bolterandchainsword.com/topic/293618-logan-grimnar/#findComment-3742638
I havent seen the ork codex to make any assumption, my point merely was that in his current format in 5th & 6th edition, he allowed for the creation of a legal, all Wolf Guard army. (Battleforged)
In 7th we can take unbound armies which are all Wolf Guard should we so wish without the need to take Logan, I just wondered IF he became a Lord of War and to justify him becoming a Lord of War, is it because of his ability to make all Wolf Guard armies battle forged?
https://bolterandchainsword.com/topic/293618-logan-grimnar/#findComment-3742661
That would make slightly more sense than what I'm expecting, as Ghazkull lost the Warboss ability to take some Nobz as troops (as did Warbosses), gained nothing and his points cost didn't massively change (still between 200 and 250). So the best we're likely to see imo is Logan getting the Chapter Master 4W, but that'll be it. Other Chapter Masters (or just the 200+ point special characters) will probably have to wait until their army gets a dex to be 'upgraded' to LoW.
https://bolterandchainsword.com/topic/293618-logan-grimnar/#findComment-3742753
Logan might be out of stock (When I checked a minute ago he wasn't, but who knows. Maybe he's just out of stock in some regions), but that probably just means they need to do another run of his model. The battleforce disappearing is significant, though. I'd agree that it looks like we'll be getting our own boxed set of some kind similar to the IG defense forces or SM Strikeforce.
On HQs becoming Lords of War: The problem is that these HQs are not competitive with other Lords of War- Escalation games are designed to be ~2.5k games with each side having their own lord of war. With cheapo lords of war, this becomes a problem a) because one army ends up taking up a lot of time due to extra models, whereas an ordinary escalation game is basically a normal game with one jumbo model to each side (Unless you took a baneblade, but then, you're playing guard and everything in the guard codex takes up a lot of time, being a horde army, after all), and b) The best counter to another lord of war is your own one. And Logan and Ghazgkull can't do that. A suped up Bjorn might, though.
https://bolterandchainsword.com/topic/293618-logan-grimnar/#findComment-3742756
