Lord Kallozar Posted July 13, 2014 Share Posted July 13, 2014 hi all, just wanted to know which weapon set is the most effective for a Helbrute? and secondly, which of these two weapon sets would you choose if you had to: Helbrute with Reaper Autocannon and Thunder Hammer OR Helbrute with Missile Launcher and Thunder Hammer? cheers. Link to comment Share on other sites More sharing options...
incinerator950 Posted July 13, 2014 Share Posted July 13, 2014 I'd take a Ra or MM with a TH instead. I'd also opt for a TLLC instead of the TH with the ML. Link to comment Share on other sites More sharing options...
Iron_Within Posted July 13, 2014 Share Posted July 13, 2014 I don't agree with the assumption that a ML needs to go with a Twin Linked Lascannon, especially now the ML is no good at taking out Vehicles (which I might add is ludicrous, Krak is meant to be a vehicle killer!). Rather if you want to take a ML take it with a Plasma Cannon or Reaper Autocannon. The Plasma Cannon and ML make it a half decent Infantry killer as it has the tools to take on MEQ, TEQ and GEQ, with an Reaper you can take on light vehicles. I personally think the Plasma gives more options. I would also say don't take a ML unless you're planning on taking it as part of the 5 brute detachment. Along with the rage choices it makes a nice way of getting more shots. It's expensive and a bit subpar, but tbh Hellbrutes in general are a bit subpar (we should really just stop using that word, Chaos is subpar). Anyways, the reason way is whenever you're glanced despite the fact you have a 1 in 3 chance of running at the enemy it turns into about 1 in 1 with sods law. Another decent way to run the Hellbrutes is in the Mayhem pack. A thunder hammer would be a good choice along with a Multimelta in this config. The Mayhem pack has drawbacks (no scatter mitigation), but if it's in a rush list the mayhem pack will throw a massive spanner in the works, 1 AV12 unit is easy to deal with, 6 (3 Hellbrutes, 3 Maulerfiends) bearing down on your is almost impossible. Link to comment Share on other sites More sharing options...
incinerator950 Posted July 13, 2014 Share Posted July 13, 2014 I forgot about krak missiles beong almost useless. Link to comment Share on other sites More sharing options...
Xenith Posted July 15, 2014 Share Posted July 15, 2014 I forgot about krak missiles beong almost useless. Not useless for glancing vehicles to death. They're still more likely to strip a HP than the plasma, probably about the same as the reaper vs AV12, and better than the reaper at AV13. Link to comment Share on other sites More sharing options...
