Nova_chron Posted July 14, 2014 Share Posted July 14, 2014 Hopefully the title says it all looking for some help on doing heat discoloration on engine vents and exhausts mostly on my storm raven then possiby expanding to other uses. Any help would be amazing Link to comment https://bolterandchainsword.com/topic/293734-heat-scaring-on-exhaustafterburner-ports-an-weapons/ Share on other sites More sharing options...
Mahoo Posted July 14, 2014 Share Posted July 14, 2014 While not exactly the same, you could do the same thing people do with flamers. Drybrush the surrounding area with a brown, then drybrush more tightly around the area with some black. A quick and easy effect but looks pretty good. I've seen people use blues and purples and the effects look beautiful, although I've no idea how they achieve that effect lolhttp://www.bolterandchainsword.com/topic/287114-painting-burnt-barrels-for-plasma-and-flamer-weapons/?hl=%2Bflamer&do=findComment&comment=3618813 Link to comment https://bolterandchainsword.com/topic/293734-heat-scaring-on-exhaustafterburner-ports-an-weapons/#findComment-3744796 Share on other sites More sharing options...
Grotsmasha Posted July 14, 2014 Share Posted July 14, 2014 As above with blue/purple wash/shade. Check out the Tutorials section, iirc, there a family recent addition that covers what you're after. Cheers, Jono Link to comment https://bolterandchainsword.com/topic/293734-heat-scaring-on-exhaustafterburner-ports-an-weapons/#findComment-3744879 Share on other sites More sharing options...
Ovidius Incertus Posted July 14, 2014 Share Posted July 14, 2014 I usually do successive washes of sepia, devlan mud and badab black moving further toward the nozzle/muzzle end. It takes a lot of washes and a lot of drying time to do, but the effect is good. That's with silver/gunmetal colored nozzles. I've started adding a purple wash to the mix on some of my flamer/melta nozzles that are painted with a brassy color. Link to comment https://bolterandchainsword.com/topic/293734-heat-scaring-on-exhaustafterburner-ports-an-weapons/#findComment-3744960 Share on other sites More sharing options...
Forté Posted July 14, 2014 Share Posted July 14, 2014 Look at photos or real jet engines. They often don't have a scorched look but do have a slight heat discoloration. Purple, blue,and sepia glazes should work. Link to comment https://bolterandchainsword.com/topic/293734-heat-scaring-on-exhaustafterburner-ports-an-weapons/#findComment-3745099 Share on other sites More sharing options...
Nova_chron Posted July 15, 2014 Author Share Posted July 15, 2014 Yeah that is what I was looking for Forte just how to pull it off Link to comment https://bolterandchainsword.com/topic/293734-heat-scaring-on-exhaustafterburner-ports-an-weapons/#findComment-3745339 Share on other sites More sharing options...
Forté Posted July 15, 2014 Share Posted July 15, 2014 Have a search on aircraft modelling forums. Bound to be loads of information there. Link to comment https://bolterandchainsword.com/topic/293734-heat-scaring-on-exhaustafterburner-ports-an-weapons/#findComment-3745648 Share on other sites More sharing options...
Voxxel Posted July 18, 2014 Share Posted July 18, 2014 Check this article: http://fromthewarp.blogspot.nl/2011/09/how-to-paint-heat-stained-gun-barrels.html It gives really useful tips on how to do this! Link to comment https://bolterandchainsword.com/topic/293734-heat-scaring-on-exhaustafterburner-ports-an-weapons/#findComment-3748411 Share on other sites More sharing options...
SCOTT_FRANCIS Posted July 18, 2014 Share Posted July 18, 2014 I used a metal, a silver, a brown, a grey and then mixed up the paints. I then washed half in devlan mud. This was my first attempt ever at "heat effect". Link to comment https://bolterandchainsword.com/topic/293734-heat-scaring-on-exhaustafterburner-ports-an-weapons/#findComment-3748703 Share on other sites More sharing options...
Nova_chron Posted July 20, 2014 Author Share Posted July 20, 2014 These all look great once I have some good time to sit and tinker with sprue for practice I will give it a go on a model Link to comment https://bolterandchainsword.com/topic/293734-heat-scaring-on-exhaustafterburner-ports-an-weapons/#findComment-3750015 Share on other sites More sharing options...
