depthcharge12 Posted July 14, 2014 Share Posted July 14, 2014 Like it says, have you guys found any veteran squads to be useful? I can imagine with certain legion traits like IF and WEs that you can make good shooty and assaulty vets respectively. Now I know that the vets can be a bit pricey but they do well at taking down certain units. Now I'm thinking of making some dark angel veterans with 2 plasma, 2 power weapons, and a power fist. I plan to give them the sniper rule so as they move up the field, they can lay down some ap2 hate and take down possible threats like terminators and castellex from range and do preliminary charges to prevent those units from getting charge bonus'. I'm also thinking of trading out the two plasma for 2 volkites as their deflagrate should also get the sniper rending too ;) Any other good combinations you guys have had or good ideas? Link to comment https://bolterandchainsword.com/topic/293745-veteran-squads-good-load-outs/ Share on other sites More sharing options...
Reyner Posted July 15, 2014 Share Posted July 15, 2014 That is how I am planning to run my Veteran Squads, are you going to transport them at all? I was tempted to put mine in a Rhino and then with the Iron Warriors RoW I can assault after rapid firing the plasmas (once they exit the Rhino since you can't assault after disembarking one). Link to comment https://bolterandchainsword.com/topic/293745-veteran-squads-good-load-outs/#findComment-3745643 Share on other sites More sharing options...
depthcharge12 Posted July 15, 2014 Author Share Posted July 15, 2014 That is how I am planning to run my Veteran Squads, are you going to transport them at all? I was tempted to put mine in a Rhino and then with the Iron Warriors RoW I can assault after rapid firing the plasmas (once they exit the Rhino since you can't assault after disembarking one). That's an awesome idea I overlooked. Is it just bolters or is it really all rapid fire weapons? :) Link to comment https://bolterandchainsword.com/topic/293745-veteran-squads-good-load-outs/#findComment-3745854 Share on other sites More sharing options...
Ishagu Posted July 15, 2014 Share Posted July 15, 2014 I have 10 guys in a Rhino with a Combi Melta and 2 Meltas... Link to comment https://bolterandchainsword.com/topic/293745-veteran-squads-good-load-outs/#findComment-3745967 Share on other sites More sharing options...
Reyner Posted July 18, 2014 Share Posted July 18, 2014 That is how I am planning to run my Veteran Squads, are you going to transport them at all? I was tempted to put mine in a Rhino and then with the Iron Warriors RoW I can assault after rapid firing the plasmas (once they exit the Rhino since you can't assault after disembarking one). That's an awesome idea I overlooked. Is it just bolters or is it really all rapid fire weapons? I believe it is all Rapid Fire weapons. It would be amazing if it was their Legion special rule rather than their Rite of War as I would have a load of them scoring running the Pride of the Legion RoW. But alas I will just have to add them as Elites :P Link to comment https://bolterandchainsword.com/topic/293745-veteran-squads-good-load-outs/#findComment-3748604 Share on other sites More sharing options...
Sanct Posted July 18, 2014 Share Posted July 18, 2014 alpha legions vets with 2 suspensor'd missile launchers, sniper and a metal box (rhino). Take the Alpha legion tankhunter rule and give them a whirl. Link to comment https://bolterandchainsword.com/topic/293745-veteran-squads-good-load-outs/#findComment-3748949 Share on other sites More sharing options...
