Astoran Posted July 15, 2014 Share Posted July 15, 2014 Hi. Pretty sure this has been adressed but I cant seem to find it. How does the Wolf Tail Talisman work now in 7th? Is it a 5+ dispell like in previous eds or do you use dice as normal but get success on 5+? Thanks for your help :-) Link to comment https://bolterandchainsword.com/topic/293766-wolf-tail-talisman-in-7th/ Share on other sites More sharing options...
Vash113 Posted July 15, 2014 Share Posted July 15, 2014 Unless FAQ'd otherwise I'm pretty sure it's a dispel on a 5+.. Link to comment https://bolterandchainsword.com/topic/293766-wolf-tail-talisman-in-7th/#findComment-3745528 Share on other sites More sharing options...
Cpt_Reaper Posted July 15, 2014 Share Posted July 15, 2014 This came up at my local club. We reason it goes like this: - opponent declares power - opponent rolls for warp charges - wolf player attempts DTW - fails DTW - dispels power on another single roll of 5+ Link to comment https://bolterandchainsword.com/topic/293766-wolf-tail-talisman-in-7th/#findComment-3745538 Share on other sites More sharing options...
Baulder Posted July 15, 2014 Share Posted July 15, 2014 Aye, until it is FAQ'd then you get this roll as well as the normal DTW. So roll your DTW as normal then after go for a 5+ if you fail. Also it is worth noting that this doesn't have the same limitations as the normal DTW roll (where you need to get a number of denials equal to the number of successful rolls to nullify). One dice, one roll, irrespective of WC etc. Link to comment https://bolterandchainsword.com/topic/293766-wolf-tail-talisman-in-7th/#findComment-3745554 Share on other sites More sharing options...
Nightwing Posted July 15, 2014 Share Posted July 15, 2014 Send some Wolf Tails to the Sons of Sigismund, brothers. We need that sort of anti-witch power :P Link to comment https://bolterandchainsword.com/topic/293766-wolf-tail-talisman-in-7th/#findComment-3745560 Share on other sites More sharing options...
Astoran Posted July 15, 2014 Author Share Posted July 15, 2014 Thanks guys. Then I had it right last night when I went up against demons. We had a little argument regarding this and I ended up not using it at all. Link to comment https://bolterandchainsword.com/topic/293766-wolf-tail-talisman-in-7th/#findComment-3745589 Share on other sites More sharing options...
tjdudey Posted July 15, 2014 Share Posted July 15, 2014 does the power/psyker have to be within 24" of the bearer of the talisman? Link to comment https://bolterandchainsword.com/topic/293766-wolf-tail-talisman-in-7th/#findComment-3745608 Share on other sites More sharing options...
Dantay VI Posted July 15, 2014 Share Posted July 15, 2014 No, the wolf tail talisman is something you give to a character model to act as their personal psyker shield Link to comment https://bolterandchainsword.com/topic/293766-wolf-tail-talisman-in-7th/#findComment-3745622 Share on other sites More sharing options...
Captain Coolpants Posted July 15, 2014 Share Posted July 15, 2014 I'd say it's a modifier to your usual dtw roll in this edition. Which would give you a 5+ dtw with powers being directed at you. That's how it use it anyways, don't see why you'd get a normal dtw and then talisman roll, nobody gets 2 separate rolls. Just seems fair the way I see it Link to comment https://bolterandchainsword.com/topic/293766-wolf-tail-talisman-in-7th/#findComment-3745638 Share on other sites More sharing options...
Grey Mage Posted July 15, 2014 Share Posted July 15, 2014 We used to get three, for a short while:Runic Staff, WTT, and then Deny the witch.Then it was FAQd to be only one roll. That statement however is out of date, but it does show clear intent Id say. Link to comment https://bolterandchainsword.com/topic/293766-wolf-tail-talisman-in-7th/#findComment-3745662 Share on other sites More sharing options...
Baulder Posted July 15, 2014 Share Posted July 15, 2014 We used to get three, for a short while: Runic Staff, WTT, and then Deny the witch. Then it was FAQd to be only one roll. That statement however is out of date, but it does show clear intent Id say. I think the lack of statement in the latest FAQ shows clear intent that they are not likely to be updating the existing codex further to be in line with the 7th. Bring on the new codex!! With that said the previous statement was that you had to choose, so it wouldn't have had an effect on the functionality of the talisman, which to my mind has never been altered. Therefore, the "fair" way to play it would be to use either your DTW dice pool, or the talisman if you are targeted with a power. Otherwise just DTW as normal. I think Jbat is correct and it will probably be our own adamantium will but until that day Jbat, it is as it reads (5+ to dispel, not a bonus to deny the witch). Link to comment https://bolterandchainsword.com/topic/293766-wolf-tail-talisman-in-7th/#findComment-3745667 Share on other sites More sharing options...
