Converting a Khorne Juggernaut Lord
Thinking of adding a chaos lord riding a juggernaut to my chaos space marines force and I'm wondering how you might go about converting one. Jugg itself is easy, just use one from the skullcrushers box but I can't think of any chaos space marines legs that would fit nicely on the jugger. I could always just use the skullcrusher legs and throw a CSM body on top, but I'd rather use an all CSM model if there is a good way to make it work.
most of the conversions I've seen use the Fantasy Khorne Lord on Juggernaught. Just use the legs from that. Replace the torso if desired.
Never had either of the models in my hands, but I'd wager a guess and say Juggernaughts and Thunderwolves should probably be about the same size for the saddles. So maybe a pair of Viking Powerpants would fit your Lord.
Though the Skullkrusher Riders legs would probably be fine, if you feel inclined you'd just have to add a bit of volume to the calves and they are 1:1 SM compatible, imo.
Don't forget that Magmatrax's whole body is quite a bit bigger than the average CSM mini. Here's the list of parts he used. I'm not quite sure, but I also think the plastic Juggernaughts look a little sleeker than the old metal version, something to keep in mind.
