Leman Russ turret interchangability?
I've played AM/IG for a while, but never actually purchased a Russ (heresy, I know), but I'm about to break down and buy a couple, which brings me to a question: if I buy both the Demolisher and the MBT kits, can I use the turret options from one with the turret for the other? Such as building them as a Demolisher and a Punisher, or converserly a MBT and an Exterminator. If it's just minor work needed, that's fine, but just kind of looking at my options before I decide which kits to buy.
The turret assemblies are interchangeable, yes. The actual turrets themselves on the MBT need a lot of work if you want to swap between the MBT/Eradicator/Exterminator.
The Siege Tank kits for the Demolsiher/Punisher/Exterminator actually are designed to have interchangeable barrels that can "clip" in or out, if you build them right.
