Brother Ambroz Posted July 25, 2014 Share Posted July 25, 2014 So I've used Citadel primers before in the past without this problem but the latest model I just sprayed the other night has layered the model with a gritty texture along with the black paint. Was this because of environmental conditions or because of distance? Anyone have some experience with this? Link to comment https://bolterandchainsword.com/topic/294206-gritty-paint-with-citadel-primers/ Share on other sites More sharing options...
Grotsmasha Posted July 25, 2014 Share Posted July 25, 2014 Typically, it's both environmental conditions and distance, the grit is caused by the paint partially drying in the air before it gets to the model (that's how it was explained to me at least). So try to avoid spraying in direct sunlight and over and the peak of the day. Morning and afternoon shade was what was recommended to me here in sunny Brisbane. Cheers, Jono Link to comment https://bolterandchainsword.com/topic/294206-gritty-paint-with-citadel-primers/#findComment-3755429 Share on other sites More sharing options...
Brother Ambroz Posted July 25, 2014 Author Share Posted July 25, 2014 Thanks for the reply Grotsmasha. I was actually in the garage so I don't really think the sun had an effect on it, but the distance may have. Guess I'll have a go at spraying closer next time. Link to comment https://bolterandchainsword.com/topic/294206-gritty-paint-with-citadel-primers/#findComment-3755453 Share on other sites More sharing options...
Subtle Discord Posted July 25, 2014 Share Posted July 25, 2014 I've always preferred spraying closer then recommended, but moving much faster to compensate. Something I've picked up from having to prime in less than optimal conditions. (Winter sucks) It usually helps the spray get in to some of the tighter spots as well, but you need to take care to keep your layers very light. Link to comment https://bolterandchainsword.com/topic/294206-gritty-paint-with-citadel-primers/#findComment-3756075 Share on other sites More sharing options...
netminder69 Posted July 26, 2014 Share Posted July 26, 2014 You don't want to spray more than 12 inches away. Link to comment https://bolterandchainsword.com/topic/294206-gritty-paint-with-citadel-primers/#findComment-3756301 Share on other sites More sharing options...
