Vulture Proxy / Conversion / Stand In?
captain sox
Got a few Valks, and was thinking about the Vulture Gunship. I have a lone Nephilim that I was considering using as the Vulture. Could be easy to retrofit some weapons onto it.
What do the rest of you use, if you field one at all. Personally, I dislike the model because, being an aviator, I can't figure out the setup of the darn thing....
provide pics if you can!
thanks
https://bolterandchainsword.com/topic/294378-vulture-proxy-conversion-stand-in/
I'll be using this and mounting two massive Gatling guns to its "cheeks" to ride into battle, with the Heavy Bolter hanging down on the chin, (or maybe rear-mounted, it never says how the HB is mounted.)
I think it's a sufficiently pretty model to be preferable to the Valkyrie chassis, at any rate.
I second the dakka jet. Makes for a great conversion if you don't add the ork bits and don't mind it looking like an old Mig. Plus can be seconded for a Avenger if you want. Doesn't really have the "hover" feel to it I believe but considering most people never actually "hover" their Vultures I'd say it would probably work alright. Depends on if you like the model though.
Nephilim could work I suppose it just looks a bit small compared to a Valk to me.
DoC
