Spraying wolves
Haakon_Stormbrow
Hey all i have a new technique for painting models of late where i pick a light colour and ink it dark rather then start dark and layer my way up.
It makes speed painting way easier. For instance my squat army (using mantic forgefathers and played as chaos with the nurgle upgrade on everything) is just sprayed yellow and inked brown then highlighted, and it looks fantastic.
Anyway since i'm in the process of redoing my wolves i need some help for an appropriate spray colour.
My Idea is to go half way between 30k Codex Grey (Dawnstone) and 40k space wolves grey (Fenrissian Grey).
(forget shadow grey (or The Fang), i hates space wolves painted with that)
So If we take Equal parts of Codex Grey (Dawnstone) and Space Wolves Grey (Fenrissian Grey), that would be my base, with highlights of equal parts of Space Wolves Grey (Fenrissian Grey) and Fortress Grey (Administratum Grey), with a final blueish 100% space wolves grey.
Ill get the darkness by Inking using 50% black and 50% blue (nuln oil and drakenhof nightshade)
But for speed, and a base colour i want to start with 100% Fenrissian/Space Wolves Grey.
Does anyone know of any company that make a spray in that colour or as near to it as possible, i don't mind it being a little darker but it needs to be closer to fenrissian grey then it does the fang.
https://bolterandchainsword.com/topic/294703-spraying-wolves/
I agree haakon i been doing this i started my wolves last year. I spray army painter space wolves grey black wash mixed with a bit of brown and then russ grey. done
is army painter space wolf grey lighter then the fang?
or even, is as its name imply the same as go's old space wolves grey?
I was thinking maybe a conversion of a spraying wolf...
I have seen some great armor color using the A.B. spray primer. Washed with a little agrax or sepia then gone over with '_________' color. Easy. Breezy. Beautiful, Space Wolf armor.
End of Line
So you want a bluish grey but not TOO blue? Maybe check my thread. I did some experiments with mixing colours to try and achieve that. I wanted relatively less saturation, and a slightly more turquoise tint. I am still playing around with it as although I had settled on a scheme I want to switch to Vallejo as much as possible, as it is a lot cheaper and better.
RPR... that really sounds contradictory right there, haha! A bit greyer but no less blue? Umm..!
AP's wolf grey is definitely darker than old space wolves grey, but then again that was a realy light colour. It looks more like old shadow grey (or rather a halfway step between the two, similar to the current Citadel russ grey). I'd also like to know how it compares to the fang, because I'm really struggling to decide on a grey for my wolves and I'm quite curious about both.
well i have to re-paint my tau, start my squats, repaint 50 space wolves and all of the vehicles, paint my elder harlequin army and standard elder force, paint my grey knight force, start from scratch on my brothers orks, finish my necrons. and paint all my factions from my new game called deadzone.
so i am a little behind and think i fall into the batch painting category.
only think i really want to airbrush in space wolves though are my vehicles due to the lard flat surfaces.
If all you are using it is for basecoating models, then the GW airbrush is adequate for the price, then you just mix the shade you want and dilute. The bottle on the spray gun is marked so you dilute it the right amounts and off you go.
Cheap as chips, but only useful for base spraying.. It's useful to me as I have nowhere for a compressor etc and my shed has been broken into a few times. It runs off of a can of compressed air/gas which is handy too.
if I'm basing only screw the GW spray gun, ill use spray cans, i want a hitch sprayer for details and vehicular shading.
but basically i am after which companies make good hobby "spray paint" for undercoats so i can either find a space wolves grey my self or if others have found a colour like what i want to list it here.
at the moment the armybuilder wolf grey is winning for best spray
Didn't GW just announces that they're release a Space Wolf Grey primer/spray can?
Contradictory, you say??!! I don't believe they really exist.
End of Line
Bear in mind that the fang spray is, like it was before, a limited release. At some point they'll just stop stocking them, and then you'll be stuck undercoating fang from a pot by hand/spraygun/airbrush if you have it if you want any new additions to your great company to match the ones you based with the spray can. The degree to which that bothers people will vary tremendously, of course.
Personally, I can't decide on a shade of grey at all for my wolves, but I'm leaning towards a mix of two Vallejo paints as a basecoat which, if it works out, I'd replicate en masse by mixing several pots together into a big dropper bottle with a widget and then I'd probably prime my minis a neutral grey colour and brush it on by hand.
