Gondow Posted August 10, 2014 Share Posted August 10, 2014 This just turned up in a game. Will both models be hit or not?Template rule is not very helpful, neither are the building ones... ...and page refs. is very welcome :) Link to comment Share on other sites More sharing options...
Morticon Posted August 10, 2014 Share Posted August 10, 2014 models can only be removed from line of sight - so which models can be seen? otherwise, if they can both be....ya :/ Link to comment Share on other sites More sharing options...
Chaplain Admetus Posted August 10, 2014 Share Posted August 10, 2014 P 173 has you covered for template weapons. It can't hit both, as the template must be placed where it covers 'as many models in the target unit as possible, without touching any other friendly models'. Ergo, the template cannot be placed where it would clip the chaos marine, assuming the Chaos Marine is on the same side as the Heldrake. If the Chaos Marine and Meph are not on the same side as the Heldrake (desperate allies/team game) then it would legitimately hit both, as it must be placed where it clips as many models in the target unit as possible, since both units are only 1 model you can place it anywhere where it covers the 'official' target, and the other one is just unfortunate. Re: The building, the template weapon again has a section with the 'No Escape' rule, so any models inside take hits if the template covers a fire point. Link to comment Share on other sites More sharing options...
Morticon Posted August 10, 2014 Share Posted August 10, 2014 Do we have to place the template on the ground, or hold it above the model? Link to comment Share on other sites More sharing options...
