Good place to buy bases?
If it's not a standard size, go with Litko. They do lots of odd ball base sizes. As a matter of fact, here's your exact base: http://www.litko.net/products/Rectangular-Miniature-Bases%3A-1.5x3-in.html
Now keep in mind, they custom cut these out of plywood. They aren't plastic or resin. You do get to choose the thickness from a few choices.
If you need just the one (or maybe a few), why not cut it yourself from plastic sheet? If you can’t find sheet thick enough, laminate two or three pieces.
Or, as one guy in my game club did when he needed a square base for a figure from another game that he’d obtained without one: stainless steel smile.png
Thanks for the suggestions, guys.
The reason I need a base of a very odd size is to use them for... Toy cars .__.' Hot Wheels cars. Using them for a game I got of a wargame website, that sells rules and such.
Currently using cut photocopy paper, sticking them with sticky tac.
I asked the guy that made the rules on his blog, he sticky tac'ed his cars on transparent bases. He said they were custom made from Galeforce9. ohmy.png
So you need more than one or two? You could try going to a hardware/DIY store and browsing around, for all you know they have something of approximately the right size — or if you ask nicely, maybe they’ll saw a plate into pieces like that for you (though I suspect they might say 38 mm × 76 mm is too small). Or: you could buy a strip of wood, plastic, aluminium, or something similar of about 4 cm wide, then saw it to length yourself.
If you manage to find a square base that is 1.5x3 inches, do let me know as it will be breaking the laws of geometry :)
All rectangles are squares but not all squares are rectangles. Or something like that. I may have gotten that backwards. :P
It's more like "all squares are rectangles but not all rectangles are squares".
