Left handed combi weapon?
What do you mean? A combi weapon attached to a left hand?
You can probably just take a regular combi weapon, and attach it to the pistol or ccw wielding left hands available in the ASM box.
Huh, well if you're going to be smart about it, there is nothing I can do.
I think either there were a couple instances of mostly jovial sarcasm, a case of interpreted sarcasm followed by more sarcasm but either way I'm gonna second what Xenith said, cut off the right handed bits from the combi-wep and just graft it onto left hands that can be easily found in the ASM squad. I've done that type of conversion a couple of times and it usually works okay.
I...don't get your meaning?
Let me clarify: Combi bolters are ambidextrous. Cut the hand off the combi weapon, cut the pistol from the left arm piece, attach combi weapon.
Sorry, I was being silly because you had a very simple and elegant solution that should've been obvious to me but wasn't.
Haha, no worries, I thought that was the case, I guess it's my Olympian paranoia shining through tongue.png
Watch for stuff like combi meltas, though, they are sculpted with the melta pack on the outside when in the right hand, making it hard to be held across the body when held left handed. On an outstretched arm, they should be fine.
Across the body is so 2000s, plus it hard to look badass in that pose.
Yeah, this is something I've though about doing in order to get some left-handed bolters.
Although this model is usually shown with the open hand I believe that the other two left hand options in the kit are combi-weapons. Plasma and melta, I think.
Combi plasma and storm bolter. The combi plasma is in the storm bolter form, side by side, as opposed to the usual on top or underslung versions.
