Vijok Posted August 15, 2014 Share Posted August 15, 2014 I've downloaded an Android version (1.14.02b) and I can't find the right file for 7th edition and DA. BattleScribe shows an Error info on all repositories that I'm trying to use :( Since my search-fu is so weak, can You help me? Pretty please! Link to comment Share on other sites More sharing options...
Cactus Posted August 15, 2014 Share Posted August 15, 2014 Try this repository, if you haven't already: http://battlescribedata.appspot.com/#/repos You can also download individual files from here: https://github.com/BSData/wh40k ...and raise issues here: https://github.com/BSData/wh40k/issues However, the latest version of Battlescribe is 1.14.05b so I'd try installing that first. Link to comment Share on other sites More sharing options...
SvenONE Posted August 15, 2014 Share Posted August 15, 2014 I think there was a hiccup in the repositories recently. Also, make sure you've got it selected to the 7th edition settings as well, I noticed that the 6th option was lacking some codexes. Link to comment Share on other sites More sharing options...
Polythemus Posted August 16, 2014 Share Posted August 16, 2014 if you have a desktop its pretty easy to add the units and points values you need in order to gain the forgeworld units that are most common and fix other things (note that battle scribe has knight master of DWK with only 2 attacks) Link to comment Share on other sites More sharing options...
Vijok Posted August 16, 2014 Author Share Posted August 16, 2014 I've tried those files and they didn't work, so it must have been a problem with my tablet, couse now everything is ok. Thanks. Yup, I know that BattleScribe isn't perfect and needs some work (like I can't give a sniper rifle to a scout sarge). Link to comment Share on other sites More sharing options...
