He Will Not Die
Gentlemanloser
How's this for a HQ?
Brother Captain, Cuirass of Sacrifice, Two Nemesis Falcions, Psycannon, Melta Bombs (194)
Same stats as a Grand Master (bar PML2), with It Will Not Die and FnP.
(If you don't mind the PML1, you should note you can replace the 35 point upgrade to a GKGM with the 4 point upgrade to Falcions...  Go go internal Balance...)
https://bolterandchainsword.com/topic/295531-he-will-not-die/
I wish I had a few more of the metal GKT Psycannons, I only ever had the one before the plastics came out, so I use him as a Psycannon BC/GM.
I miss the look of the old Psycannons, they look so much better. It's the barrel and the ammo box that I really don't like the look of on them, for the same reason I leave off the cartridges on the side of the Storm Bolters.
Ah ok,  didn't realise that.  I guess if you could get him sanctuary that would be pretty good.
4+ invul is very strong though, especially if you get FNP as well (which unless they have S8+ or ID, you will). If you're really that keen for Sanctuary, take Stern instead, he comes with it standard.
