redmapa Posted August 27, 2014 Share Posted August 27, 2014 The other day I realized I could infiltrate terminator squads and thought that was a great way to maximize body count, since Im not going to get the second book in some time I'll be using the generic legions rules, either stubborn or furious charge otherwise this'd be Imperial Fists and I'd make some room for Sigismund. So here it is my reworked list, Fistwing! Fistwing 1990HQ 340Praetor 150-Paragon Blade-Iron Halo-Digital lasers-Melta bombs-Pride of the Legion2x Vigilator 170Elites 320Dreadnought 160-Multimelta-Drop podDreadnought 160-Multimelta-Drop podTroops 925Terminator Squad (9) 355-7x Power fist, Combibolter-Sgt Combi bolter,Power Sword-Reaper Autocannon, Power fistTerminator Squad (9) 355-7x Power fist, Combibolter-Sgt Combi bolter,Power Sword-Reaper Autocannon, Power fistVeteran Squad 215-2x Meltaguns-OutflankHeavy Support 405Vindicator 145-PotMSVindicator 145-PotMSWhirlwind Scorpius 115 A quick question, if a model has a single lighting claw does it still get Shred? If it is then there will be a mix of 5 termies with LC and 3 with PF plus the sergeant. Im also a bit on the fence with the veterans but dont know what to change them for, I think I could change it for a mortis dread with lascannons and an attack bike with MM, should I? Link to comment https://bolterandchainsword.com/topic/295883-sneaking-into-the-fray/ Share on other sites More sharing options...
Kilofix Posted August 27, 2014 Share Posted August 27, 2014 Just remember that models with Augury Scanner (e.g. Apothecaries) can prevent you from Infiltrating within 18". Link to comment https://bolterandchainsword.com/topic/295883-sneaking-into-the-fray/#findComment-3791612 Share on other sites More sharing options...
redmapa Posted August 27, 2014 Author Share Posted August 27, 2014 True but they also have scout which will help them move forward so I can always deploy 19'' away and then scout 6'', or is scout movement before infiltration? I have to check it. Link to comment https://bolterandchainsword.com/topic/295883-sneaking-into-the-fray/#findComment-3791636 Share on other sites More sharing options...
Transgressor O'Malley Posted August 29, 2014 Share Posted August 29, 2014 You could also play Alpha Legion and give everyone infiltrate as standard. Link to comment https://bolterandchainsword.com/topic/295883-sneaking-into-the-fray/#findComment-3793804 Share on other sites More sharing options...
redmapa Posted August 29, 2014 Author Share Posted August 29, 2014 Yeah but I prefer IF and Sigismund is a beast, Im only using the vigilators to bring more bodies instead of a land raider to transport the terminators. 2000 HQ 400Sigismund 230 2x Vigilator 170Elites 475Dreadnought 160-Multimelta-Drop podDreadnought 160-Multimelta-Drop podMortis Dreadnought 155-2 Twin-Linked LascannonTroops 720Terminator Squad (10) 360-3x Power fist, Combibolter-5x Lighting Claw, Combibolter-Sgt Combi bolter,Power Sword-Reaper Autocannon, Power fistTerminator Squad (10) 360-3x Power fist, Combibolter-5x Power Sword, Combibolter-Sgt Combi bolter,Power Sword-Reaper Autocannon, Power fistHeavy Support 405Vindicator 145-PotMSVindicator 145-PotMSWhirlwind Scorpius 115 A bit of a change. Link to comment https://bolterandchainsword.com/topic/295883-sneaking-into-the-fray/#findComment-3794551 Share on other sites More sharing options...
Slips Posted August 29, 2014 Share Posted August 29, 2014 Hopefully those dreads don't run into armored ceramite units or those Meltas wont be worth jack :x Link to comment https://bolterandchainsword.com/topic/295883-sneaking-into-the-fray/#findComment-3794569 Share on other sites More sharing options...
